Guishnu Posted June 15, 2012 Share Posted June 15, 2012 June 2012: Chaps, I have been reading through reams and reams of threads giving conflicting views. Can anybody give me a definitive answer? Will R33GTST Callipers and Rotors Fit a RWD S2 Stagea? (front and rear) Cheers Chris Link to comment https://www.sau.com.au/forums/topic/402646-definitive-answer-%E2%80%93-will-r33gtst-callipers-and-rotors-fit-a-rwd-s2-stagea/ Share on other sites More sharing options...
Daleo Posted June 15, 2012 Share Posted June 15, 2012 Yes, BUT you will need to sleeve the mounting bolts on the front calipers from 14mm to 12mm. Link to comment https://www.sau.com.au/forums/topic/402646-definitive-answer-%E2%80%93-will-r33gtst-callipers-and-rotors-fit-a-rwd-s2-stagea/#findComment-6401521 Share on other sites More sharing options...
jet_r31 Posted June 16, 2012 Share Posted June 16, 2012 yep sleeve as said..i to spent ages reading all that shit, and its 2 posts of good info..and 8 pages of shit going around in circles...lol cheers darren Link to comment https://www.sau.com.au/forums/topic/402646-definitive-answer-%E2%80%93-will-r33gtst-callipers-and-rotors-fit-a-rwd-s2-stagea/#findComment-6402118 Share on other sites More sharing options...
pipster11 Posted June 16, 2012 Share Posted June 16, 2012 (edited) r33 onto s2c34 - sleeve (12mm id, 14mm od) r34 onto s2c34 - bolt on you might want to pull one of the caliper bolts off first tho and measure the shank of it, it seems like the rwd's have a slightly different mix of parts than the awd's so you might just have 12mm bolts like an r33/s14 (pretty sure i read somewhere that rwd's have s14 front suspension) Edited June 16, 2012 by pipster11 Link to comment https://www.sau.com.au/forums/topic/402646-definitive-answer-%E2%80%93-will-r33gtst-callipers-and-rotors-fit-a-rwd-s2-stagea/#findComment-6402370 Share on other sites More sharing options...
66yostagea Posted June 17, 2012 Share Posted June 17, 2012 Yes, check the bolt diameters. We recently fitted S1 RS4 fronts to an S1 RWD but non turboed. We had to drill out the fronts to take the 14mm bolts. While to fit the GTST fronts we had to sleeve the caliper to take the 12mm. Nissan topsy turvey. Link to comment https://www.sau.com.au/forums/topic/402646-definitive-answer-%E2%80%93-will-r33gtst-callipers-and-rotors-fit-a-rwd-s2-stagea/#findComment-6403335 Share on other sites More sharing options...
4bidn1 Posted June 18, 2012 Share Posted June 18, 2012 S1 c34 rs4 to r33 GTST direct bolt on for future ref Link to comment https://www.sau.com.au/forums/topic/402646-definitive-answer-%E2%80%93-will-r33gtst-callipers-and-rotors-fit-a-rwd-s2-stagea/#findComment-6404446 Share on other sites More sharing options...
pipster11 Posted June 18, 2012 Share Posted June 18, 2012 S1 c34 rs4 to r33 GTST direct bolt on for future ref this is well established, there are a lot of awd's about what the OP is wanting to know is the brake options for his (what i assume is) RS (rwd turbo) which were a series 2 (usually 14mm bolts eg r34) but because is doesn't use gtr running gear there is no way to 100% know without pulling a bolt out Link to comment https://www.sau.com.au/forums/topic/402646-definitive-answer-%E2%80%93-will-r33gtst-callipers-and-rotors-fit-a-rwd-s2-stagea/#findComment-6404706 Share on other sites More sharing options...
Guishnu Posted July 7, 2012 Author Share Posted July 7, 2012 Just to update this thread. S2 RS RWD Stagea will accept R33 GTST callipers and disks. They bolted straight up. The car uses S14/S15 running gear. Link to comment https://www.sau.com.au/forums/topic/402646-definitive-answer-%E2%80%93-will-r33gtst-callipers-and-rotors-fit-a-rwd-s2-stagea/#findComment-6433706 Share on other sites More sharing options...
KiwiRS4T Posted July 8, 2012 Share Posted July 8, 2012 The car uses S14/S15 running gear. Maybe some....not all Link to comment https://www.sau.com.au/forums/topic/402646-definitive-answer-%E2%80%93-will-r33gtst-callipers-and-rotors-fit-a-rwd-s2-stagea/#findComment-6433843 Share on other sites More sharing options...
Guishnu Posted July 8, 2012 Author Share Posted July 8, 2012 Maybe some....not all Don't know about the shock length - but lower arms (F/R) hubs and carriers (F/R) connecting arms are all interchangeable with S14/S15. The diff looks different and i'm not sure about the connecting points on the subframe. Link to comment https://www.sau.com.au/forums/topic/402646-definitive-answer-%E2%80%93-will-r33gtst-callipers-and-rotors-fit-a-rwd-s2-stagea/#findComment-6434440 Share on other sites More sharing options...
pipster11 Posted July 10, 2012 Share Posted July 10, 2012 Just to update this thread. S2 RS RWD Stagea will accept R33 GTST callipers and disks. They bolted straight up. The car uses S14/S15 running gear. i think he is refering to the rwd models Link to comment https://www.sau.com.au/forums/topic/402646-definitive-answer-%E2%80%93-will-r33gtst-callipers-and-rotors-fit-a-rwd-s2-stagea/#findComment-6436765 Share on other sites More sharing options...
Guishnu Posted July 16, 2012 Author Share Posted July 16, 2012 i think he is refering to the rwd models Yup, Hence the S2 RWD in my post :-) Link to comment https://www.sau.com.au/forums/topic/402646-definitive-answer-%E2%80%93-will-r33gtst-callipers-and-rotors-fit-a-rwd-s2-stagea/#findComment-6445975 Share on other sites More sharing options...
