seriously? I was at the tuner yesterday for 5 hours.. sure it must be a dream loll I just do not brag about my setup on the internet like some of you. I have nothing to prove and couldn't careless if you don't believe me.
but for the people really interesting ( because, yes I actually got 3 pms regarding this) about the -9, yes its possible ot achieve great number.
and here, we do not run E85 ;) we run 94.
Lol, you did brag.
Considering what sean posted, then you should get ahold of some e85, better than that 94 stuff you boys seem to run :P
dont laugh, my mate is making 286kw @ 14.5psi with gt-ss
Yeah on my built motor i made 280rwkw @ 1bar as well
End of the day mate -9s aren't going to flow 380rwkw @ 18psi, that's the simple truth.
If you really "do" have that power, take it to the strip and run near 130mph.
I bet you don't get any better than 124mph :)
True, I also referred back to the dyno comparisons spreadsheet on here and the -9's (GT-SS section) average at 303.1kw at 18.3psi which is exactly what I'm aiming for.
Maybe Cobra was running ridiculous boost? Some guys get around the 330-340kw mark with 22psi....but even that is still 40 odd HP short of 500. Not sure how far the -9's can be cranked but if you can run R33 N1s up to 25-26psi then I'm sure you can do that with the 9's as well....and that might be getting you quite close to say 360kw even though there'd be more heat created than anything else....guess it depends on where the -9's sweet spot is.
There'd always be some people out there who push parts to or past their limits....like Xkalaba and his ceramics :yes:
Edited by tommis85
Already did. Last intervention in this thread.
I'm just trying to help out the folk considering buying the GT-SS and all I get is whining and '' your a liar'' i don't believe you'' . Well, unless you pay the plane to ship my car and me to australia, unfertunately, you will never see me rollin on your drag strip.
Look at some japanese setup, they can achieve 600whp with gt-ss.
Jing R34 GTR
http://blog.nengun.c...26-tuning-world
The Jing R34 GTR has been slightly modified with Tomei and Reimax internals and two low mount HKS GT-SS turbo's. Generating 1.3kg/cm2 of boost and producing 467ps this GTR has been perfectly tuned for the street. Volk Racing CE28N wheels cover Brembo Monoblock brakes and Ohlins DFV suspension.
The concept from Jing was to retain the standard engine and easy maintenance and combine it with improved power, torque and appearance. While mildly modified, this R34 looked great.
at 18psi he managed to make 467hp but he doesnt talk about any cam and cam gear tuning etc etc. just a standard RB26, nothing else. Add bolt-on power adder and he could easily break the 500hp marks.
Okay I'm seriously done here. do your own research, I did 3 years ago, and I'm 100% happy that I went with gt-ss instead of -5 or -7
Edited by cobrAA
We're just all very astounded that's all mate. Like Piggaz asked, do you have any examples to load up? Even some video of your own car in action?
Edited by tommis85
Jing R34 GTR
Either way, even if hks gtss can make 380 odd kw, a bigger turbo would make that much eaiser and less stress on the internals.
Though do you have hks gtss or -9s. Even though most say its the same dam tubo, There is a comp sheet thats shows otherwise. but thats not the real point here
Edited by sydking
Hoping to have mine at about 25 psi,
Though if its not making much extra power past 20 then theres no real point pushing them in my books
So where are you at with your ride these days Sydking? From memory you were in my boat with too much lag? I've ended up sorting out my actuators and am just waiting to get my diff's sorted and possibly get an EBC of sorts
Did he tune it?
Yes i tuned it. Theres a few bits of info that have not been told with the setup. 2 main factors are built motor and higher comp.
Also all my dyno runs are done in 4th gear. Piggaz had the same question about the end speed with my GTR. I have alot of mechanical sympathy so i dont like to rev the engine to redline on the dyno. Most runs stop around 7000is maybe 7500.
CobrAA said 18psi
If he said 28 psi than I would believe him....maybe
But for now I still maintain mostus dynos (mustang excepted)
Over inflate by approx 100hp to what we see here
That's 340kw... which is nowhere NEAR 600hp. PS is also measured at the motor.
So 340kw, minus drivetrain losses... It's under 300rwkw (at the wheels).
Do you know how to convert?
You don't have your own drag strip?
Doesn't matter where the drag strip is, you'll never run more than 124mph - and if you do run 128-130mph, i'll gladly eat my words that you can make 380rwkw @ 18psi on pump gas.
End of the day a turbo can only flow, what it's compressor wheel will allow in terms of airflow. Simply put, at 18psi you cannot make 380rwkw on pump gas. The turbo's are not flowing enough air to do so on a 2.6ltr motor. It's simple fact mate regardless of what you have printed on a piece of paper.
Ah, I assumed you went to 8000 RPM man. Maybe I missed that bit.
Never assume anything haha
Seems like people in here wanna make 20psi @ 3000rpm and make 350kw at wheels LOL
Not me lol gees...I'm hoping to run around 18 pounds for now and make around 280-300kw. I made about 270kw with my N1s so am hoping to improve on that a bit.
Which reminds me, I should throw them up on here for sale :D
The bloke who owned my built engine before me was running GT-SS's and he reckons it made 355rwkw at something 26-28 pound (can't remember the exact figure). Tuned and built by Creatd in Vic, so dunno if their dyno is happy but it was impressive
Edited by GTR_JOEY
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
