Ok, so i needed a new shim kit for my r33. Ive got the 4 pot calipers on the front, searched for a part number, 41080-21U25 is apparently the one i need.
This, according to quite a few people, is 41080-21U25:
So i went to my nissan store, forked over a large amount of cash for that part number. Except when i got it, it looked different.
I scoured the internet again, rechecked the part number, and its definitly the one from what i can tell. It says that number on the packet I got.
Is it possible nissan can stuff it up? It came in one pack.
Id just like some confirmation. Any help would be appreicated!
Edited by Nights
https://www.sau.com.au/forums/topic/403204-front-brake-shim-kits/
It was $170 off the top of my head.
Oh really? Whats I find very weird though is that the outer shim (the silver part) doesn't cover the whole piston. It gets about half of it to 3/4.
The ones in the other pic i posted first look like the correct shape, they would cover both pistons completely.
The kit in the first post looks the same as the R32 GTR (sumitomo calipers) and IIRC the 33 gtst calipers use the same pad. The shims match the profile of the pad backing plate. So what you got doesnt looks right - but i checked the part in FAST and it came back with the same part number....weird.
Is this what your looking for? http://www.frsport.c...re_p_12970.html
Yeah i saw these originally, and they look like the exploded view of the r33 brake, but yeah, it said 300zx so i thought id be safe and go through nissan.
Yeah doesnt quite look right to me either, from a design standpoint im struggling to see why only half of the pistons are covered. Yeah its definitely the part number, although its weird cos on the exploded view they definitely match the pad backing plate. Dont look like the ones i got.
When I took off my shims, the silver ones only covered about 75% of my black metal ones =S
This is off a stock r33 gtst. Here is a pic
Yeah? Maybe it is correct then. Just seems a little weird it only covers half the calipers, not to mention its not even even, it covers different amounts of both pistons :S
This is confusing.
Edited by Nights
Mine had diagonally cut silver pieces too (R33 GTS-t brakes), apparently this plate profile helps with vibrations somehow, I've seen exactly same thing done to STI and some euro cars' backplates, so your kit is the correct one
  • 11 months later...
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
