Hi guys,
Just noticed that my front left outer cv boot is cracked so I need to replace the boot before I damage the cv itself...can I do this myself as I cannot work out how to stretch over the cv boot onto the shaft without tearing it.
Yeah there is 2 ways to do them, either remove the CV clean it and replace the boot OR use that yellow cone tools and actually fit the boot on the car, the old workshop i worked for had one but TBH if it cost $25 i would have paid someone to do it as its a greasy shi77y job :P
you would only fit the boot on the car if you were replacing a non split boot.
once the boot is split and driven around..you must remove, strip and clean then repack with new boot. Otherwise you run the risk of leaking dity in there which will destroy the CV's after a while
I can't get the outer 36mm cv nut off, I've snapped 2 extension bars and I also have a manual impact driver which you whack with a hammer...no chance :(
Looks like I'll be dropping it off at my workshop
Job done. The boot had a 1mm pinch and from that, it made a huge mess (looks like something hit it like the end of a spanner). The actual boot was the genuine Nissan boot and it was still like new, no cracks or age at all.
Kerosene all the suspension parts and inside the wheel, nice and clean the way I like it :)
Was this for front or rear axle? I am looking for the parts (boot kit) for an R33 GTR front inner and outer CV boot kit, you don't happen to have the part numbers you used do you? or where to buy them if there is a Vendor or shop on here?
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
