Just remember; anything you put in your washer bottle will end up on your paint.
I don't wash my car with Windex. :no:
Well it contains
* isopropyl alcohol
* propylene glycol
* ammonia
I was looking up what these might do to rubber & paint > went off to sleep lol
Well it contains
* isopropyl alcohol
* propylene glycol
* ammonia
I assume the first two ingredients are bad as they are alcohol based?
Can't be good for windscreen seals either..
I use Windex on a rag to clean off cutting compound as I was recommended isopropyl, but only in small doses ..I wouldn't put it in my washer, not straight anyway maybe watered down a lot...sounds like a waste of money anyway Windex isn't cheap..just get washer mix from SCA or something its like 5$ and lasts ages..I bought a bottle and sharing it between 3 cars has lasted over a year, still have half a bottle left..
Dont do it
It kills your paint, rubber, streaks like hell on glass and paint and makes your wipers dry out and shutter / hop destroying the motor and blades as they move across
The evaperation is too fast at speed and it makes a mess
The only time you need anything beyond water is if it gets below freezing ( which will crack your bottle and lines ) even the stuff posted above stuffs your detailed car up , best left for old crappy cars and mud bog trucks
You can buy paste glasswax and it works to keep bugs off and water stains or rain ex if applied in a few thin layers works but only at speed , its meant for race cars and planes
Just buy decent blades and change them yearly
And just like anything rainex and wax wears off , do it as part of a detail job min to keep acid rain or tap water from etching the glass
Edited by Carbon 34
Nothing beats new blades, So quite, No streaks, No mess. Cheap and under 10 min to install
Though i have been looking for a good Glasswax like rainex ect.
Can anyone comfirm if thats the sam stuff the race cars use when they have stripped all wipers and washer bottles?
I use Rain-X on my windows, and they do a washer additive that I also use. It doesn't leave any visible residue or spotting on my paint.
It seems to stretch out the time between reapplication of Rain-X, especially in the wiper track; which always wears off first.
Definitely agree with new wiper blades; also helps with reducing wiper track scratching, as the blades get older with more rubbish embedded in them.
Edited by Daleo
Yes its the real stuff but built up over lots of thin layers to work, you can buy glasswax from USA its pretty cheap under 20 bucks some megs wax works but beware some waxes stuff the wipers and they shudder bad , those silicone blade suck too unless its a downpour , splatters of water they clean to well and the backstroke is bouncing blades
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
