so I got my car recently and i want to give drifting a go. question is that I'm a low baller and cant afford lessons with Project D let alone being able to drive a manual is a requirement. I've got a R34 GT auto. is it possible to drift with tiptronic?
Serious question guize :yes:
I feel the heat coming on soon :angry:
https://www.sau.com.au/forums/topic/403907-learning-to-drift/
  • Replies 53
Yep, Texi will let you enjoy the car and try slide it... I think sliding is possible but drift would be pretty hard in an Auto and without power etc... But by all means come out and have a crack :)
Yep, Texi is well worth it - it's not exactly drifting, but you will learn a bit about what you and your car are capable of (or not!).
First-time entry fee = $35
AASA Licence = $50 (lasts for a year)
Helmet = approx $80-300, depending on what you want.
Wear long sleeves, long pants, enclosed shoes, and you're set!
as much as you decide to lay down really :D
If a $35 texi is an issue funds wise, don't worry about looking to hard into any form of serious motorsport including drifting. They are all really hard on your car, and require heaps of maintenance between outings, not to mention entry fees, travel to and from venues, fuel etc.
Just get out and give some motorkhanas and maybe hillclimbs a go - they are designed to be quick, cheap and fun for normal people with normal budgets.
And then if you win lotto you can build a carbonfibre bodied r35 for time attack
Well all good advice in here. Texi is an excellent starting point. Agree that sliding an Auto is dificcult but not impossible. Would require a lot of handbrake and throttle over work. Leave it in 1st or 2nd so the rev's stay up. Never tried it myself so cannot comment further.
Simple priciple on drifting though, if you can't hold a 2nd gear wheel lock slide then you most definately won't be able to do one at 100k's pluss. Learning to do low speed angle control is where it all begins and you can practice your heart out at our Texi Skidpan.
Shutdown :unsure:
I can afford the texi entry fee but in terms of maintenance and tyres is a no go for me. Apprenticeship wages suck balls :yucky:
I think I'll wait until I get more money or get on my fulls then get myself a GTT.
^ Good advice!! :D
What brand are your tyres? Most cheap hard tyres take a lot of punishment before wearing (hence why they grip like crap anyway lol)...
The ones I'm rolling on now is Ovation and on my set of stock wheels are Kendal Radial. JUST REALIZED I HAS ANOTHER SET OF WHEELS (after i forgot i had the stockies out back) :woot:
You can have a go in my car if you like?
Oh but no screamer pipes :P
Cant drive manual but. and what would you consider as a screamer? I think my pipe is a bit loud (for me anyways). maybe around 100db. it was like that when i got my 34
100Db is pretty loud. screamer pipes are generally on turbos (i don't know if they even go on NAs?) - look something like this
these are horrendously loud
dave's joke about no screamers was meaning his car won't be out there because he has a screamer. even if you just come along and watch texi, and see if you want to enter next time? hop in a few cars or something too - if you want to do that, just make sure you've got ankle to wrist clothing - helmet needed too. MCAS has cheap ones :D (my last one was ~ $60 - this will last you a lifetime)
A "screamer" is where the waste-gate gasses coming off the turbo are vented to atmosphere instead of being channelled back into the exhaust, and because it's not muffled, it sounds like a scream.
Your exhaust should be fine if it's street legal.
C'mon, do it! Bring the spare tyres if you think you'll need them - it's better to have them and not need them, rather than need them and not have them. If you do wear out a set of tyres, at least you'll still have a set to get you home safely.
lol....
p.s. unless you get a engine cutout defender thingo ie: stops the car from stalling when handbrake is applied fast you cant use the handbrake in an auto without going into neutral, using handbrake then going back into gear.
So basically all you can do is "Power over" drifting and then possibly link corners from there, in all seriousness you are just going out there to do skids and look cool and have a laugh and enjoy yourself like everyone else :)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
