A mate was moving my car off his front lawn, when he started it spluttered and stopped and now there is not a hint of it even wanting to fire.
I have checked my power fc sensor check and every thing looks fine, i changed the ignition module with no luck, the cas is showing 2-3 degree's when cranking and 0 if unplugged, have unplugged the tps, cas and afm with no difference but they all do should up as faulty in the sensor check screen, i can here the fuel pump prime but just to be sure i took the fuel line off and there is plenty of fuel flow.
From here i have no idea what to check next, any idea's would be great.
check for spark, check for fuel. If there is spark, and there is fuel coming to the rail, then check fuel pressure (pinch the return hose and see if that changes anything).
if u have spark, fuel, pressure, then put an LED/noid light on an injector plug and make sure uve got injector pulse.
if uve got everything, it should start and id be asking my mate what else he did other than moving it off the lawl :P
I know there is fuel there but not sure of pressure, i'll check that, as for what my mate did, he was as hung over as f**k and didnt even want to go out side so im sure he wasnt cutting hoops around the block lol, he wouldnt do it if he was sober.
  • 3 weeks later...
+1
Check spark and injector pulse
Check spark plugs
Check fuel pressure
Check timing belt
Check compression
in that order
I have checked everything except compression which im sure would not drop low enough on every cylinder that not 1 cylinder would fire and checking if the timing belt has slipped a tooth or two, the belt is still intact and tight.
Also tried a different ecu and once again not a hint of firing on any cylinder.
Any other suggestions?
Is the cas aligned with TDC compression stroke?
how do i check that?
I did replace the cas with another one i have here but its been sitting out in the car port for a while so im unsure if it works, the shaft has surface rust so im unsure what condition the internals would be in, it has not been in the rain tho.
Have you checked all the fuses, any major vacumn leaks? also you can take the CAS apart to check the shaft isnt broken..sounds like when my cas broke..
Edited by SliverS2
Yes but wen u penetrate the opening u have to have it aligned correctly....
Theres a keyway in the exhaust cam as the cas must be aligned with TDC compression stroke otherwise the ecu has an incorrect reference.
Hard to explain but pull the cas out and have a look in the centre if the shaft. Then look inside the opening. U should notice a key way which should stop the cas being inserted incorrectly but if the keyway is missing its a little harder to align
No vac leaks, but even if there was one the car would still atleast fire on a couple of cylinders, have not checked fuse's or relays tho, will do that when i get some light.
It is in properly then, had to fiddle with it before it would slide into the D shaped keyway, untill it did the cas would not slide all the way in.
I think your cas might be broken inside, its happened to me before and i wondered why the car wouldnt start , then when i took it apart i could see the shaft was broken..
I also decided to not use the front timing belt cover anymore cause i wasnt sure if it was stuffing up the alignment..
Edited by SliverS2
For those with the same problem check the fuse marked "starter" dont assume that this is for the starter motor and dont bother checking because the starter is working fine, its actually for a "starting circuit" which is apparently separate from the ecu, and even if it looks fine change it any way.
Also after flattening the battery many times trying to start it you have probably screwed your plugs and cleaning them wont help so get a new set!
Lessons learnt :/
  • 4 weeks later...
So it was just a fuse? If so you must not have checked ignition/fuel correctly, as it will only cut one of those out.
Apparently The fuse reduces the injector pulse to a point where it wont get enough fuel to fire but still enough to show a pulse on a multi meter.
No idea why its there or even if that info is correct but it does explain why everything checked out fine but it really wasnt.
Wow that is annoying, we had a similar problem where the wrong earth had been used for the ignitor, it could sink enough current to spark, but the spark was really really weak and wouldn't actually fire.
Had to strip the loom apart to find the proper earth when we wired it up again, took ages to figure that one out.
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
    • Going by the intake & injectors I'd be guessing it's a DE, check the head casting number, should be 5L8 on a DET, 5L7 I think is the DE number.
