I didn't find a DIY on here for front wheel bearings so i thought i would post a guide as to how to do it.
the replacement part is number 8 in this diagram and can be purchaced through http://justjap.com/ for about $240 each.
Part number is 40210-AL800.
and thanks to Jetwreck for the diagram.
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=304447
details will be up next and the tools required for the job.
OK the tools u will need are either spanners or sockets in sizes: 12mm 14mm 17mm 19mm 22mm and 32mm
I suggest a big breaker bar or if you have it a rattle gun. Also you will need a ball joint puller (well really its a pusher LOL).
Some long nosed pliers to take out the split pins and a rubber mallet.
Step 1: jack the car up and pull the wheels off.
Step 2: you will need to turn the wheels to gain access to the bolts from the callipers which are 22mm, then proceed to take the calliper off (also you might want to undo the 12mm bolt holding the brake line on the strut for more length) and then u'll have to get that rubber mallet out and bash off the disc.
Step 3: take off the steering rack limiter (2x 14mm bolts) on the strut to gain access to the ball joint as to get a puller in there to pop out the steering arm. (you will need the puller as its bloody tight even trying to prop it up and then smash the crap out of it with a rubber mallet didnt work ** note when tapping all the studs out keep the nuts on there so u dont damage the threads)
Step 4: carefully remove the sensor from the strut it is also glued in there so be careful not to damage it whilst prying it off, then hang it up out of the way not to get damaged.
Step 5: undo the remainder of the bolts there will be 2x 19mm on the bottom and the 17mm on the top by the A arm, once they are all knocked out and loose also undo the 32mm bolt holding the hub on the axel. then give it a tap with the hammer to get it loose but dont knock it in more than 25mm / an inch.
once its all loose you might want a hand to carefully pull the entire arm/strut out of there taking particular care with the axel and the part the sensor reads because u dont want to damage that!!!
then once its out u can either push the bearings out yourself but i prefur to take it to a pro and get that done by them as they have the proper tools.
So Guys its really not that hard at all just involves a bit of time depending how seized stuff is but basically anyone can do it if they have the tools then all you have to do is get the old and new bearings pressed in and away you go.
also a side not when your putting back in the steering arm you might need to apply a bit of presher with a jack from underneath as to stop it from spinning when u go to tighten up the nut.
so anyways i hope this helps everyone out.
Edited by WAGON_BOY
Nice work Theo.
Not how I do it but still nice work.
I just drop the bolt off the top of the arm off and rattle the main axel bolt off rather than removing the whole arm.
You don't need to remove the upright li k as you did. Just remove the hub/bearing separate from the upright link and take that in to get the bearing pressed out/in.
Also I don't bother with a ball joint puller. Just leave the nut on a couple turns and use a rubber mallet and give it a whack on the side of the ball joint and out she pops. Normally only takes one whack.
Just a heads up for guys doing it then selves and they don't have a ball joint puller.
Edited by slippylotion
Nice work Theo.
ok doing it that way u get access to the 4 bolts holding the hub/bearing doesnt that need to be pressed out or could've i just whacked it out with the mallet?
mine were locked in good i couldn't whack it out............ but i had a puller anyways so might aswell use it
Mine where really tight....couple of beers and a good pull got it done.
Lolz....just read that back.....IMHO need for an edit! :P
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
