Hey
So I have been a Skyline fan since I was a kid and unfortunately never had opportunity to make a car purchase a Skyline... Until now! I'm looking to get something cheap for my first one but still an R34, turbo, manual. something I can put my business logo on AND be the beginning of my motor sport for me.
I think I have it nailed down to these 2 cars but i'm open to similar if you see any!
The basic pro differences to my eyes are
Navy:
FMIC
19 inch Akita wheels
Adjustable rear camber arms
171,000KM
White:
Heavy duty clutch
Drilled and slotted rotors with extreme motorsport pads
Turbo timer
138,000km
Here is my assumed on road costs. Let me know what you recommend and why :D
NAVY BLUE
Purchase $9,500
Insurance $304
Registration $1,037
Coil packs $600
TOTAL COST $11,441
WHITE
Purchase $11,500
Insurance $304
Registration $0?
TOTAL $11,804
Im pretty sure theres a thread on here somewhere about buying a skyline and what to look for.
Chuck up a link to the cars, people might be able to help more with more info
Have you done a revs check on the cars?
Why's rego so expensive on the blue one?
How much do you know about cars?
Will you be doing work yourself?
What colour do you like? White is easier to keep clean than blue
this is the thread (http://www.skylinesaustralia.com/forums/topic/35129-im-buying-a-skyline-what-should-i-look-for/) that r31slpr was referring to.
good, in-depth guide to inspecting a car thoroughly. very helpful
^^^^^DO NOT listen to the person above. While the above advice might actually be helpful , you never know when the trolling will start , hence disregard everything he says.
The guide posted above is your best friend.
That is all.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
