Similar thing happened to my wifes WRX all of a sudden was only running actuator pressure a week later back to the normal 12psi. Suspect the stock solinoid had a fault give yours a good clean out and then send 12v through it an make sure its working
Those stock solenoids in the WRX are a pretty common issue too. Can go either way. My mates one failed on the track. He saw 28psi before he realized and backed off.
Im leaning towards the stock solenoid in this GTR too. See of anyone has one thats been removed they would let you try out?
  • 7 months later...
I am getting the same things as the OP. I have a R32 GTR with a R33 GTR engine and ecu.
When it happens, I stop. Turn the car off. Turn the car on after 2secs and its back to normal.
Everything is stock except for exhaust and boost restrictor removed. I tried another standard solenoid and had the same problem. The solenoid is normally open at idle then when you apply throttle it switch's off OR its the other way around. I have also tested the solenoid with a 12v power source, its fine. When the fault happens the solenoid no longer changes its state until I turn the car off and turn it on again.
My train of thought is something electrical is putting out a signal that is making the ecu think something is wrong when its an intermittent fault, which explains why when you turn it back on, all is good. I will put some new plugs in, check the coils external physical condition, check the soldering job in the AFM's and check various connectors for bad earths and corrosion.
This seems to be a common problem with GTR's but I haven't been able to find a fix for the problem. The best suggestion was to check earths and for corrosion in plugs.
I have a standard air box.
I fixed the problem.
It was the AFM's.
They had been resoldered in the past but 2 joints weren't done very well. So I redid all of them.
Voila! Fixed! Hasn't played up in a week. Before it was doing it every trip, even short ones.
I should mention I changed plugs at the same time as my old ones were worn, and I made sure the coil pack earths were clean, which they still were from last time I cleaned them. But I am pretty sure they had nothing to do with it as the car was running fine before it would drop to low boost.
  • 4 months later...
Sorry to revive a old thread but i have the exact same problem.
This issue is very intermittent and has also occured on my old S15. The way i would describe it is "losing both engine response and boost" only when the car gets hot. mind you my car is 100% stock even with standard airbox. i noticed if i leave car on idle for 2 mins or switch car off it will fix the problem immediately.
I've been trying to diagnose the issue for some time now. first i thought it was due to engine oil, so i switched to 10w-30. then i thought it was fuel injectors so i got those professionally cleaned no. also changed fuel filters, engine coolant temp sensor, 02 sensors and coil packs. NO CHANGE!
So it AFMs the last resort?
It should have been the first resort, it is well known the AFM's require re-soldering occasionally and the dry joints manifest as intermittent power loss as you described. Check the 'how to' tutorial.
  • 1 month later...
Its the AFM's. Mine started doing the problem again but not as often. The AFM's are old, that's pretty much it.
Need to find someone who can repair these things.
  • 4 weeks later...
I found out that if you unplug the water temp sensor (for the ecu, not the gauge) it does the same thing as when the intermittent fault happens so I would recommend changing that plus the air intake temp sensor on the plenum.
  • 5 weeks later...
And the problem is still happening. Its rare though now. Change the water and air temp sensors, nothing.
Probably cas, ignitor or AFM getting a glitch. Happens when the air temp is absolutely stinking hot or on a really cold night.
Try the AFM, i didnt believe it was a common issue till i opened my GTR's AFM meters up and found 1 barely connecting and the other one totally not connecting, a few minutes with a knife to remove the cover and some solder brought them back from the dead and fixed my problems.
On the bright side, even if it does not help, you have ensured this problem wont get in your way down the road and cause other issues.
Yep, I opened up the AFM and resoldered the joints. They looked dry but still attached. The problem went away for a while after doing that but has returned. I'm pull the AFMs out again and resoldering EVERYTHING.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
