  • Replies 142
Ok u melted your last motor and you thought that it was the fuel pump yet u still have not changed it ??? Now your saying the new one is running lean ??? Isnt that giving you alarm bells or do u just have more money than sense ?
We all take our cars to a good tuner.
Mine is yavuz at unigroup engineering at girraween.
The man is a genious with pfc,also tunes others.
If you want your engine to survive get it checked and tuned.
Only way to be safe. :D
Cheers mate how much for a tune does it cost u
Obviously not as much as your cuz.
How about this then smarty pants, dont ask about why your csr runs like shit and your afr's are all over the place. You know what is the first thing that will be said, GET A TUNE!
It is parramount and you would be utterly stupid if you drive it without getting it tuned! But seeing as you have the money to throw around at rb26's it shoukdnt be a problem for you
Now frosty we have a rb26 running lean it should not lean out unless it's over boosted and the fuel
Pump can't supply enough fuel to keep up it does not need a tune because it's a standard car with a standard computer
Now a couple of things could go wrong one of the airflow meters could be buggerd the injectors could be clogged or believe it or not a 02 sensor could be damaged which usually causes a lean mixture but if it was hit with a exhaust wheels since I blew a turbo which it was the o2 sensor would be shorting out giving the ecu a incorrect voltage causing a lean mixture because it's reading a constant 4.5 direct voltage Any body out hear actually no something about cars around here and not just bust out with tune a standard car lmao
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
