Sau Vic 2012 Motorsport Championship Round 5 - Sandown 11Th August
  • Replies 307
Posted Images
Nah I have to pump the guards before I give the car to them. The only time I have is this weekend. So I'm hoping I can get it done. I'll be lifting the car for them too.. Dropping it to them isn't a worry
I don't know how much camber they will put it for a 'track setup' someone said they'll put quite abit in. But don't know if they were talking about fronts.. Eh I should be able to get another 3-4mm out of it. So with a but more height shod be fine
on the cams application form it has PO box 427
and under the contact us section on there site has PO box 147
any difference in the two? wanna send forms of today.
[email protected]
will solve all of your worries. and will receive the license much quicker.
Are you using a heatgun on the paint Aaron?
Yes you will need to for sure. Rob did his with a roller and gun, plus some scotch.
Athid is a sure bet though, will be done perfect.
yeah hes done a real clean job on your car John...what would be the charge to get all 4 done you think..
finally figured what is rubbing on my car and its not the wheels at all...its the dump slighty hitting underneath my car ....must rememebr to fix that
Couldnt have done it without the Scotch!
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
