  • Replies 224
my photographer friend will be attending to take photos and video if that's ok with all...
www.baldockcreative.com.au
He holds a motorsport media pass and has done shots at Mallala before for a drift event once.
I am looking forward to just coming out and meeting you all. No racing for me... This time... by next track day all of the work should be finished. It has been a long time since I tackled Mallala...
Alrighty mine should have been all paid up a bit ago so hopefully you guys got it.
What kind of lap timers do you use? I have one that i'm borrowing at the moment that hopefully I'll still have for the event, just wondering if they will use the same base stations :)
So what i have read its all cool to come out and have a watch?
I would love to join out on the track but i think im to late to put my name down
and don't have a skid lid.
Plus cars needs oil cooler and few other things first.
Sorry, clear it up - last time we paid for one prior to the day, but there was no list (except where shown on here) so they gave them to the people at the time and some missed out despite paying - myself included. I know they're not free for all lol - so made do with the iPhone App and was told would get one in the next SAU:SA track day
http://www.skylinesaustralia.com/forums/topic/388555-sau-sa-track-day-5-with-passengers/
(refer to 3rd person on the list lol)
