Funny thing about motorsport... NO warranty!!!
Follow all the tempering rules you ever learned and know to work, 3 days into a realy tough event and thump...thump...thump...thump...thump...thump...thump...
Not just one but two cracks on each rotor.
These are sold as high performance.... I forget what brand they are!
Guess I need a bias bar and some days testing now. More power is good, pulling it up is a problem!
TT
https://www.sau.com.au/forums/topic/40587-when-your-brakes-break/
EEEKKKK!!! That cant be good! :Oops:
There no good to you now, so id at least send them back to the retailer/manufacturer with a letter stating what happened.
Your not likely to get anything out of them, but at least they will be aware of the limits of their rotors and MAY (?) change the metallurgy or heat treatment they use for that range of rotor...or qualify there claim of high performance ;)
i popular brand or replacement rotors are they?  the same as i have on the front of my car by the look of the slots, not good.
the slots may be good for cleaning the pads but give a high stress point by going out to the edge of the rotor
No drama with fronts Clint... They are much wider(Thicker - more heat dispersion). And yes, even though I dont work for a brake company, I would say the cracks started in the slots.
Used OEM for rest of the event with no drama.
Redline
TT
I know what you mean, i've seen that pattern before somewhere...
And funnily enough the front rotors look the same as to what are set to be going onto my car.
And i aint seen that pattern anywhere else yet....
Are you sure you dont remember TT? Just not saying to be diplomatic?
Even PM me if you like rather than post it openly.
Shoot that's impressive TT, I have never seen a Skyline rear disc do that. Where they hardened? What pads? Same compound front and rear? Do you have an adj pressure (limiting) valve on the rear? Was it showing signs of excessive rear brake bias?
Standard Brake config.. ie no bias adjust, no limit knob, no hydraulic h'brake etc.
Pads in rear ebc green stuff, fnt = Red Stuff (V3) - ebc cant supply RS for rear. Drove on the street for 2-3 weeks. 50 dyno runs, and a day at Baskerville (12 laps). But never servere on brakes - my style tends to be float 'em in rather than stop turn shoot (lack of power dictates that) Then Day 0, 1, 3, and this happened at the end of day 4.
If we keep the car I will go dual with bias adj for next year, and dial it in on the heat paint/infra thermometer.
As for bias indicative symptoms, at the end of symmons plains straights, (damp) it picked up the fronts slightly, without locking the rears.
I don't like the slots to the edge... will use oem style on the rear next time. Unfortunately with the wheel size cannot make enough gains to warrant bigger discs (commercial decision). Thats why we are looking to move to an N1 BNR32.
Oh, and it does it when cooling. They are fine until cooled - maybe in Tassie they cool too quick??
Not just one but two.
TT
Not a good result Tom.
For those that couldn't work it out from the hints, they are DBA rotors and this is very rare.
If you dont mind emailing me Tom I will replace the discs with new ones if I can get these broken discs back for testing. We take pride in our work and do replace "No Warranty" items if we can't offer a reasonable explanation. You just need to ask the right people... :)
Thanks!
Steve Gavin
Disc Brakes Australia
[email protected]
Nice -- good to see a company standing by its products :(
Edit: out of interest, what sort of cost is associated with DBA rotors, and would people recommend the 5000s over the 4000s, etc?
LW.
LW, i'm a big fan of the dba 4000 series after the experience i had with my soarer. It did have a bit of power behind it and after changing to the DBA 4000 series rotor's up front it stopped miles better than before. Stopping repeatedly from high speed was a real option where as before on the standard discs you'd get some bad fade after a few hard stops. If it can stop a tank like that every time without any fuss I'd definately reccomend it for a 32R :) I'll let you know when mine go on which should be sometime in the next month or so.
If you dont mind emailing me Tom I will replace the discs with new ones if I can get these broken discs back for testing. We take pride in our work and do replace "No Warranty" items if we can't offer a reasonable explanation. You just need to ask the right people... :(
Thanks!
Steve Gavin
[email protected]
Thanks Steve,
I will email you for details... Even though I didnt expect a replacement, as you can understand - being a relatively low budget operation - we are very greatful. (And I wouldnt have named them)
Every now and then during racing you have a product that for what ever reason does not perform to your expectation. Given the many variables, it is refreshing and almost unheard of to get this response.
For all those wondering, we also run the same model front rotor, without any problems, in fact same car or different car, I will use the same product in Targa 2005...
That is not just because I like the way they do business, but I am convinced they have a good product. (Some top brands sold in Oz are branded - I believe - by dba for their clients).
Regards TT
PS. Yes Gaz, We always roll the car while waiting for time cards etc... even If we have to reverse back to get it. Also you get 200-500 meters of run down, which gives a fair bit of knock off time.
If you dont mind emailing me Tom I will replace the discs with new ones if I can get these broken discs back for testing. We take pride in our work and do replace "No Warranty" items if we can't offer a reasonable explanation. You just need to ask the right people... :P
Thanks!
Steve Gavin
[email protected]
Well.... That was unexpected!
I'm running 330mm DBA discs on alloy hats with AP Racing 6 Pot Calipers and am about to upgrade to 365mm discs as I've decided to go exclusively 18" wheels for track and road.
With that kind of response and product backing how can I not go for DBA discs again?
Wonderful to see a company back their products like that and genuinely interested in product testing and research.
Nice -- good to see a company standing by its products :D
LW.
5000's are a two piece rotor.
4000's are a single, both are the same 'rotor'
It's just that the 5000 cost more initially, but cost less to replace.
The 4000 are cheaper, but cost more to replace.
Get what i mean?
And DBA Steve, with that comment, my faith in my brakes on the car has been lifted. Definately going to stick with the custom 5000's and the 4000 on the rear (which are there now with no breaks yet :P)
Get what i mean?
Certainly do. What sort of cost is involved in the purchase though -- I had a quick look and couldn't actually find any prices online.
LW.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
