  • Replies 56
remove jacket one from uploaded thumbnails. people will get confused lol.
when do you want money by?
how do we pick sizing - and measurement:size?
/fatshit
Edited by Sunkist
/fatshit
Harsh will have that info soon
For anyone that has tried these on (if any) - what is the sizing of these like? I got a large SAU hoodie and it was really short...
The hoodies has funked up sizing.
We have a sample of the Large. I'd me going a Medium.
I've seen the sample and sizing seems quite generous.
But I think the plan is to Have the large sample at the garage Meet in a couple weeks time to try on.
edit:
meet up thread
http://www.skylinesaustralia.com/forums/topic/406142-august-monthly-meet-come-try-on-a-jacket/
Aaron...sorry to say it bro...your size doesnt exists in the world at the moment...looking the the X's on the first post for your size, we'll have to join ten jackets to make one fit for ya...lol
Haha so it's the same with you right?
Indians...
I'm thinking jacket 2, red clashes with my eyes
Hmm, so I'm changing my eye colour eh,
Where do we specify a size or are you asking before placing an order.
L would be good for me.
  • 11 months later...
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
