http://www.ebay.com.au/itm/130696551537?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
hey fellas this is cheap as chips so i thought id buy one, any one used it before? and can you recommend if i should run it with the waste-gate/ turbo separator in or out? what do you think boys?
https://www.sau.com.au/forums/topic/406130-dump-pipe-advice/
  • Replies 66
Posted Images
If you were to use it, the separator is an essential part. There is no point having a split dump unless the flows are actually split, and the only way to do that is to have the separator in there. This design is "fabricated" in that the separator is attached with fasteners. Others are welded.
But even if you were to want to use a split dump, you wouldn't buy one of these because the short ones are shite. The only ones worth considering are the ones that are a full dump and front pipe unit in one, and the split is dropped back in a long way down.
right now i understand! well ive got a spare few bucks so im gonna give it a go, and ill let you know how it goes, my current one has a leak on the gasket so, for the price of the gasket might aswell swap it for this. cheers blokes!
Just keep an eye on your boost gauge, you don't want to blow an engine, or the turbo for that matter...
will do, im installing a r34 smic and rb20 actuator at the same time, so i planned on giving most of my attention to the boost gauge on the first drive! haha!
http://www.ebay.com....984.m1497.l2649
read the words then keep your smart arse comments to your self. the advice i was after was should the separator be kept in or not, not if i should buy it as i stated i have already bought it.
but on a lighter note, thanks for the help people!
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
