I got some about three years ago. Ran them in my RB25DET up to about 240awkw. Now they are in my RB30/25 knocking on 300awkw expect to get to 330 - 350 with them. If I were buying today I would buy ID1000s (more expensive then DW) as I would like to run E85 in the future and have a Greddy copy plenum so could run an RB26 fuel rail but if you have sidefeed only the DW should be fine.
There is a thread in this section about them, Might be a bit hard to find due to the spelling though.
From what i gathered when i was researching injectors for my upgrades a while back, they will do the job but they dont have as good of a spray pattern as nismo injectors.
get some ID 1000's or 750's for $700 including postage from InjectorsOnline, you need a top rail though, Artz has the 750's, and i just did it with 1000's, far better injector from what ive heard , if you have time and some reasonable skill you can set them up yourself.
Edited by SliverS2
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
