hey people, just wondering because its pretty fustrating. doesnt matter how much soap i put it suds up nice for first few seconds then after you start using it, it goes to water,
ive tryed maguires wash and wax, and mothers carwash (both not cheap products)
i first put hot water then use gerni to get it mixed nicely
anything im doing wrong?
https://www.sau.com.au/forums/topic/406490-carwash-soap-doesnt-sub-up-well/
ideally the best way is to first fill up your bucket with water then add the soap whist mixing it in by hand - the reason for this is that you want the soaps and suds to be kept inside the water, keeping it slippery and lubricated
so when you use your mitt/sponge to absorb it and go over your car, there is the maximum amount of slip and lube between the mitt and your paint
IMO bubbles are wasted lubricant that should be in your wash solution not on top
also pretty basic but make sure you are applying the correct amount of wash as per the size of your bucket - ie wash and wax recommends 30mL/4L so if your bucket is 8L, use 60mL if it is 12L use 90mL and so forth - i bought a plastic measuring cup from the $2 shop which allows you to use the correct amount without wasting any
One of the better car wash vids - if you wna skip straight to where he pours the soap into the bucket its @ about 5:00
<iframe width="420" height="315" src="https://www.youtube.com/embed/rqdEVtOPKAM" frameborder="0" allowfullscreen></iframe>
Edited by squareznboxez
Suds really aren't too important mate, Final inspections PPBS (high end soap) doesn't sud very much at all. neither does auto glyms.
All you need are lubricity and a PH balanced solution as was previously mentioned.
Suds = useless and mean nothing. People have been made to "think" that unless it 'suds up', you don't have enough or it's not a good solution.
As Jonno34 pointed out, what you want is a pH neutral solution with high lubricity. Water down some of FI's PPBS (Paint Pampering Body Shampoo) and run it through your finger tips, even diluted you can still tell the lubricity is very high.
I also wouldn't be putting my shampoo solution in a bucket either. The best way IMO is to have your buckets full of clean, hot water. Do a pre-rinse with PPBS solution and hot water and then i wash the car with a spray pack of washing solution. So as i go around i put a few sprays on the panel, a few sprays on the washing mitt. This way you have even coverage of washing solution a;ready on the panel you're about to clean.
I use an old brake-cleaner pump-pack as the pre-rinse dispenser and then an old 500ml FI trigger bottle for when i'm doing the main wash. Use less product, nice big even spray from the pack gives you good coverage of the panel and you keep the rinse water the way it should be, clean rinse water (well for as long as you can)
  • 4 weeks later...
Not necessarily true about the suds thing. I have recently bought a foam lance which hooks up to my Karcher pressure washer.
This creates a really nice thick foam that sits on the cars surface. The reason for this is to let the suds suck up any dust and dirt that isn't stuck to your paint.
You then rinse it off and begin your normal washing process whatever that may be.
I have found that this actually does work quite well, in reducing the small scratches you create when you are applying your normal wash with a microfibre mitt or sponge.
I wasn't really sold on it but i am def sold on it now.
lol science of washing a car...
Wanna know how I do it? $5 Armorall heavy duty wash and a $2 jumbo sponge. 4 caps in a regular bucket as you're filling it with water. Clears the sinuses and as a bonus it also cleans your car. Squirt panel with water, soap it up, squirt again.
Put some effort into waxing and the washing part won't need to be rocket science. On that note, I use a $7 paste wax that continues to bead after 6 months. Come at me premium products:
Pour the product/solution all over the car when wet " not mixed " Perfect system with no scratch
This is the best way by far , dont f...k around using a capful here and there = use at least a handful straight on the paint all over the car
  • 1 month later...
you quoted your own comment
-_-
Edited by w34ponGT
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
