  • Replies 80
only a bees dick of room for the turbo didnt think it would fit for a mo!
Exactly why I figure supercharged is the better option, despite the fact that the oil filter needs relocating and the power steering needs a little rerouting too.
my mate put the vortech kit on his 350z and got an extra 60kw at the wheels.
mine is on the dyno right now so i will be interested to see what gains i get.
pick it up in the morning so will post results tomorrow night
That's 81 hp at the wheels which is ok however the kit has a crap pulley as standard.you can get a different one to up the boost which is his next move.that means more money and retuning but if you change the pulley you can kiss any warranty you get goodbye
hp at wheels untuned tried a few different ecus with limited success haltech want me to ship car to nsw because they've never done an auto before but thats not gonna happen wired a new ecu up last night and its doing everything it should but not counting my chickens. if no go then off to to-mo for the uprev osiris but thats not cheap
You can do Uprev for 1/2 the price of a Haltech.
Auto can be done with a Haltech - but its not easy, and I suspect that no-one in the west has done one before. It was described as "hell to wire in" to me, thus I went uprev.
Please tell me your not running the car up to full power with no tuning? If you continue, you will break the motor.
no mate just one careful run to get an idea as soon as it was lean we shut it down. The new ecu works well on auto xr6ts so should be good. All hooked up with no issues, dyno shortly. The 123456 firing order was a surprise though.
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
