Im still waiting for the following to arrive, Tomei stud caps, Tomei 1.5mm oil restrictor, ATI 1000hp balancer and a few other bits and pieces that i have forgotten. After countless delays and f**k ups im pleased that my build has picked up speed it seems like my goal of having the car back on the road at the end of the year is still in achievable.
Edited by Tyranus
Nice one Sedat. It is pleasing to hear that things are moving. There is nothing more frustrating than waiting for things to be done.
btw - what is the flow rate of that Nitto Oil Pump? Must a be a fair bit if it comes with a head oil drain.
Cheers Anth, the only flow rate figures i could find was 64.8 @ 7k rpm. I'll need to ask my engine builder to get 100% correct answer. The head oil drain was actually an add-on that i got. My engine builder suggested that i should have a oil return line from the back of the head going to the sump so i dont have any oiling issues when im revving the engine over 9k rpm.
Edited by Tyranus
Hey Sedat you probably are already aware of this not sure if it's stated in the info that comes with the pump but the Nitto pumps runs dual springs and you need to remove one otherwise your oil pressure will be around 140 psi. PM a member on her named Shazz as he just had to remove his engine to fix that problem.
  • Like 2
  • 1 month later...
Update:
Ive purchased a Nitto 1.1mm oil restrictor
ATI 1000HP Balancer
Tomei Cam Caps/Covers i think thats what they were called
The major update:
The block is back at the workshop and is being put back together :D :D :D
The block has had its final spray (gloss black) and will be assembled this week!
And some comparison shots of rods for a 2JZ (Carrillo rod)(3.4 stroker build), RB30 (Nitto rod) and mine RB26 (Nitto rod).
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
