I'm midway through changing Stagea water pump, belt and idler & tensioner, reason being that the water pump started to weep.
1. I've got sight of the cam pulleys and when I align TDC on the crank, only the inlet cam marks align - the exhaust side cam is ONE tooth behind the mark.
I'm wondering what if any noticeable effect this would have had on the engine or the way it ran? Obviously the exhaust valves would have been slightly behind the rest of the engine.
The one problem I had with the car till now was stuttering at cruise (but it was determined not to be lockup as it showed same symptoms when out of OD) - could this contribute?
2. The other issue I have yet to solve is holding the engine still when I undo the crank pulley bolt. Manual says remove starter but it appears difficult to get to (I'm doing this on a sodden uneven driveway so jacks are difficult) and I don't have the ring tooth stopper to put in there.
cheers,
One tooth out is 7.5 degrees so you should fix it. http://www.skylinesaustralia.com/forums/topic/73824-adj-camshaft-pulley-new-cam-belt/
Try Google for holding the pulley still. I read something about a way to secure it by winding a rope around it and tying it off somewhere.
They all say to use a rattle gun but of course not all of us are so blessed!
One tooth out is 7.5 degrees so you should fix it. http://www.skylinesa...y-new-cam-belt/
Cheers, I'll get it lined up. Would be nice to have an idea of what the misalignment would do/sound like when driving. But I guess I'll find out if fixing it improves anything.
I've tried quite a few google suggestions - twisted belt locked to the alternator - broke one belt.
I have actually borrowed a 12v impact wrench which would work a treat if it fitted down in the gap. So I tried removing AC radiator, only to discover that even though it was dented and bent from a crash by a previous owner, and the AC belt had been removed, it was still fully charged. Vented freon all over me - not the most pleasant!
MIght try the starter motor crank method next...
The water pump is the VL Commodore one. And I would replace the idler and tensioner pulleys also.
You need the touch of an Angel to undo the crank nut. Get a big socket and suitable bar. Place a block of wood across to stop the bar moving and give the starter ONE hit.Have done three Stags and two CA18 this way, no probs. Before you take the pulley off return it to TDC and check all your markings
way i did mine was just to have it in 4th gear (least mechanical advantage of you trying to roll the car, spose 5th would work even better), hand brake on and got the biggest extender i had onto my socket, wrapped with a rag (so no metal-metal contact) and hit with hammer, still took a little bit but eventually got it undone, note this was also done on a sodden old uneven driveway.
The water pump is the VL Commodore one. And I would replace the idler and tensioner pulleys also. You need the touch of an Angel to undo the crank nut. Get a big socket and suitable bar. Place a block of wood across to stop the bar moving and give the starter ONE hit.Have done three Stags and two CA18 this way, no probs. Before you take the pulley off return it to TDC and check all your markings
yep got the pump, belt, tensioner and idler in a kit. surprisingly local Nissan dealer seemed to have the best deal $315. Super cheap was 290 something but not OEM.
Tried the starter method but it didn't work for me - possibly because of the shitty battery the previous owner bought for it.
Ended up wrapping a strop three times round the crank pulley and ratcheting up the tension between both tow hooks. Worked a treat.
Edited by hutchwilco
Crank pulley removal can be done with a long strong arm, put it on the big nut at an angle thats close to the chassis rail and use the starer to spin the engine just for less than a second.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
