Looking to get new rims. Does anyone here have any experience with the weight of the wheel?
I'm currently running on stock 17" (no idea how much these weight) and looking to go 19". My mates telling me heavy rims can be felt to decrease performance.
I'm not too sure how it will affect our cars as we kinda have a bit of torque to play with. But looking at some Stance sc-5ive and i'm reading their about 29-31pounds (rim only) for the 19".
Is that too heavy?
Cheers guys.
https://www.sau.com.au/forums/topic/407387-wheel-weight/
Spinning the wheels up to speed requires some power, heavier wheels will require more power, not sure how much you will actually feel this, but it is a factor.
The other issue is unsprung weight. heavier wheels add to unsprung weight and create more initeria in the suspension, meaning the suspension won't be able to react to changes in the road surface as quickly. Again, I am not sure how much you will actually feel this..
This is why people like the Rays 19s, as they are quite light.
https://www.sau.com.au/forums/topic/407387-wheel-weight/#findComment-6494967
Yeah i wonder if anyone has experienced this. Or whether or not we can feel the difference for a set that's 30 pound.
My mate's also saying that since our car has a bit of torque it won't matter that much. Might be something trivial.
https://www.sau.com.au/forums/topic/407387-wheel-weight/#findComment-6494989
As already stated it wont make a bit of difference to your acceleration - it is another 40lbs you are adding to the weight of the car - not a big figure given the thing will weigh over 3000lbs to start with.
What it will do is degrade the cars ride and its handling. The heavier the tyre/rim/brake/suspension arm set (refered to as unsprung weight) the harder the suspension has to work to keep the tyre on the road. So your 30lb wheel (which is thereabouts of 10lbs heavier than a good 17" rim) will have an effect.
https://www.sau.com.au/forums/topic/407387-wheel-weight/#findComment-6495021
This is why good quality Jap rims are expensive, and knock offs are cheap- actually, just one of many reasons.
My 19" SSR rims are 8.7kgs each(or 19lbs). Even they are not the lightest option- some RAYS rims are even lighter.
Good question. What the other guys have said is correct- your increasing unsprung weight. Remember you have to fit a tyre too, which will be wider and heavier as well, compared to stock.
https://www.sau.com.au/forums/topic/407387-wheel-weight/#findComment-6495062
I don't track, just daily driving. Not sure if the effect will be very noticeable in respect to ride stiffness or something very trivial....30 pounds are pretty heavy for a wheel imo.
Any idea what the OEM wheel weight are for our cars (i'm guessing 20-21pound for the 17" as mentioned above)?
Edited by Marshan
https://www.sau.com.au/forums/topic/407387-wheel-weight/#findComment-6495075
Its not about tracking the car and looking for every last 1/10th of performance.
Upgrading wheels and tyres smartly means looking into a myriad of different areas. Unfortunately the "flat cappers" have turned it into looking at one area- "stance".
Things to think about in reality are weight both of wheel and tyre, clearance from suspension structures, Clearance from guards, clearance from brake callipers, Rolling diameter, tyre profile, and width. Plus availability of tyres in chosen size. And lastly Legality.
30lbs is heavy for a wheel, but not the heaviest by far. Imagine all the things the wheel is connected to- suspension, brakes, gearbox, engine, wheel bearings. Changing wheels effects all those parts in different ways. I'm not saying changing wheels will blow your engine up, but pointing out that if you chose a setup with a greatly increased rolling diameter, then expect a decrease in performance. Heavier wheels, your shock absorbers will work harder.
TL/DR;
do your research, going from 17s to 19s will effect the way your car does just about everything.
https://www.sau.com.au/forums/topic/407387-wheel-weight/#findComment-6495113
It isn't just the additional weight to the car overall, it is a rotating mass the engine has to spin.
Similar to fitting a lighter flywheel, it is only a tiny difference in overall car weight, but the less mass the engine has to spin, the less power is consumed in doing just that.
But as said, I don't know how much you will notice heavier wheels, as they don't spin anywhere near as fast as a flywheel.
I would also suggest you ensure you select the correct size tyres so the overall wheel diameter is the same.. otherwise you will have all sorts of issues with your speedo..
https://www.sau.com.au/forums/topic/407387-wheel-weight/#findComment-6495399
Form>Function... Just sayin'
Seriously though, heavier wheels will cause more strain on components but it isn't a significant amount. You won't feel much difference and it comes down to what you want. As with anything, you will pay a premium for quality/brand name.
https://www.sau.com.au/forums/topic/407387-wheel-weight/#findComment-6495548
Quick question.
19" OEM rays? Which would weight lighter than the 17" i have now. Any decrease in performance?
I know that going from 17 to 19 is a big move and will have significant effect on performance and handling, but not sure how it will turn out if the larger wheels are lighter?
https://www.sau.com.au/forums/topic/407387-wheel-weight/#findComment-6499782
Why would there be a decrease in performance.
Assuming the rolling diameter is very close and the 19's are wider (usually the case with OEM), the main differences will be a greater rubber contact patch due to the wider rim-thus wider tyre (unless you are doing the stretched thing) and a harsher ride due to the lower profile tyres on the 19's.
Also you may notice a small decrease in fuel economy due to the larger contact area with the road (I lost around 0.5km/L).
Reference: I went from OEM 17's on my Stagea to Buddy Club 19's. Both weighed around the same but the BC have 245's on them (9" wide) where as the 17's have 215's on them (7" wide). Car handles much, much better with the new rims... but a lot of that comes down to the tyres.
https://www.sau.com.au/forums/topic/407387-wheel-weight/#findComment-6499990
^^ this.. no reason for performance decrese.. just rougher ride, as the lower profile tyres will absorb less..
Although if you run the same tyre pressure, the contact patch size will be the same.. just wider and shorter for wider tyres. Fuel economy may come down to the type of tyre.. maybe also a slight difference in outside diameter??
https://www.sau.com.au/forums/topic/407387-wheel-weight/#findComment-6500105
hmm... I am curious as to how you come to the conclusion that a wider tyre on a larger diameter rim will have the same contact patch as a smaller narrower rim.
I just can't see how the contact patch would be shorter for the tyre on the larger rim. Wider, yes of course... but shorter? Explain?
https://www.sau.com.au/forums/topic/407387-wheel-weight/#findComment-6500125
Contact patch size is direclty related to tyre pressure and weight on the tyre, not tyre width. A narrow tyre will have a narrow but longer contact patch, a wider tyre will have a wider but shorter contact patch, assuming the same pressure and weight. The contact patch area remains the same.
There are plently of articles about it.. but a quick search came up with this.
http://autospeed.com/cms/title_Tyres-Grip-and-All-That/A_108915/article.html
https://www.sau.com.au/forums/topic/407387-wheel-weight/#findComment-6500256
http://autospeed.com...15/article.html
I've heard of something like that too. Kinda makes sense.
I remember reading a thread on one of the 350z forums where someone was explaining that the OEM 17" might have a slightly larger contact patch than light weight aftermarket 18" due to the weight and negated grip of the larger wheel. I think you are right on the tyre pressure and weight bit.
Edited by Marshan
https://www.sau.com.au/forums/topic/407387-wheel-weight/#findComment-6500890
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
