Emad weighed 77kg on Saturday and squatted 232.5kg, thats triple bodyweight
He will smash the Open WR in the 75kg class at Worlds. The record is 615kg
In training last week he did 232.5/132.5/260 - 625kg
He has a mangled shoulder, just had a reconstruction, so his bench is down. He benched 150kg at under 80kg at ProRawThree
He has also deadlifted 270kg.
He will squat 240kg at Worlds, bench 135kg and deadlift 265-270, all at 75kg, thus smashing the WR.
Unfortunately in the major city centres your only gym options are major chains like good life and fitballs first.
Closest thing to Sydney city would have to be in North Sydney.
North Sydney Powerlifting Club
http://www.heavymetalpowerlifting.com/Club.htm
But again. they are over the bridge from sydney city and not something you can go to in your lunch break.
Comp for the Brisbane people...
What: Novice deadlift competition
Where: PTC Brisbane - 352 Melton rd, Northgate.
When: October 6th. Weigh in between 9-10, first lifter on deck at 11am.
Cost: $25
Come and test out what it feels like to lift using world class Bar Bell, Calibrated plates, specially designed lifting platform and no doubt a BBQ by world class BBQ chef.... ME!
Any SAU forum member who comes and competes, I will cover your BBQ cost.
http://www.heavymeta...ng.com/Club.htm
Cheers mate, just gonna go to SSS on the weekends and the odd weeknight when I can.
ProRawPowerlifting
NOVICE COMP
SUNDAY 7th OCTOBER
LIFTING STARTS AT 12.00PM
COST $25
ProRawTrophy – 1st
PTC Frankston, 2 Skye Rd Frankston Markos - 0404 453 542
Edited by markos
Markos - where can I get a flat bench in the proper comp dimensions? (just the bench.. not an entire bench press setup.
Just need a bench to use in the power rack I've got.
The adjustable incline/flat one I have is crap with the gap between the 2 seats and is too high off the ground.
I had Scott measure his one we used at Nats and everything I've found so far is either not wide enough or too tall etc.
this is the closest I've found
http://www.gymdirect.com.au/item/Commercial-Flat-Bench-with-wheels/240.htm
Edited by TTT
Markos, do you know of any 6ft olympic bars that have 120cm or more between the inside of the collars? But still have around 25cm worth of room for weight plates on each end? It doesn't have to have a wild weight capacity or anything and I'd prefer to try an keep costs down if possible.
Thinking about making up my own home gym, but a 7ft bar will be too long for the space.
Ladies Olympic bar is the only one on the market thats the full distance between the collars but overall shorter, so it fits in racks
They weigh 15kg and only have a 25cm diameter as opposed to 28.6mm for a full size bar
ABC sell them, not cheap, but very, very strong
How come you cant accomodate another 6" either side?
I'm limited for space in my garage and a 7' bar would only be about 10cm or less from the wall on each side.
The womens bar sounds ok, can you still fit 3 or 4 20/25kg plates on either side? (thinking longer term here)
I had a look on the abc website but I can't see the bar you are talking about. I can only see a 6'4 bar that's 18kg. It would probably be ok as well, so I'll look into both.
Do you know what the pricing is like for the abc bars, particularly the 6'4 bar and the women's 6ft? They don't have pricing on the website...
Thanks for your help
Edited by Mitcho_7
Mine is a proper needle bearing Olympic lifting bar, 15kg, cost over $500
The 18kg bars may be made for Health Spa's, should be cheap
4 plates will easily fit on my bar
Mens bar is 2200mm
Ladies bar is 2000mm
The length is taken out of the sleeve, 100mm each side
I know nothing about cheap bars, only official bars
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
