i dont think hgh by itself would be that good, definently need it with other geasr to make it do what you want...
In regards to cycling and lifting, i know a fair few tour de france riders have giant quads which would partly be due to all the bike riding they do.
back on topic..
The worlds comp in Slovakia finished up.
The number at the end of each line is their glossbrenner score (look it up - it's a formula used to take in to account age and weight etc etc.)
Results and points of Oz team at Worlds
WOMEN
Nina 330kg @ 57.3kg - 669.83
Sussy 292.5kg @ 54.9kg - 575.99
Cami 325kg @ 69.3kg - 544.00
Tish 252.5kg @ 52.1kg - 526.88
Amanda 337.5kg @ 76.7kg - 515.03
Vicki 272.5kg @ 57.8kg - 503.69
Bec 377.5kg @ 112.3kg - 497.55kg
MEN
Ricky 847.5kg @ 107.8kg - 754.28
Scott 724.5kg @ 89.9kg - 702.04
Emad 602.5kg @ 74.2kg - 679.62
Max 650kg @ 86.4kg - 665.48
Jack 745kg @ 152.3kg - 629.96
Conor 500kg @ 81.1kg - 562.14
Dan 525kg @81.7kg - 543.90
Zach 565kg @ 144.8 - 500.08 INJURED
Spiros 525kg @ 126.6kg - 492.54 INJURED
57 new Australian records were set by those people above (records can be set for each lift or total so people can actually set up to 4 records in the one comp)
There were a whole bunch of world records set too.
Edited by TTT
Here are the Australian records...
WOMEN
56kg Junior - Tish Wasson sq95/bp45/dl112.5 - total 252.5kg
56kg Open - Sussy Kollen squat 112.5kg. Total 292.5kg
56kg masters 1 - Sussy Kollen sq112.5/bp60/dl120 - total 292.5kg
60kg open - Nina Markopoulos - deadlift 142.5kg, total 330kg
60kg masters 2 - Nina Markopoulos - squat 120kg, deadlift 142.5kg, total 330kg
60kg masters 1 - Vicki Jewson - deadlift 132.5kg
82.5kg open - Amanda Woodward - sq 135/bp67.5/dl/135 - total 337.5kg
82.5kg sub masters - Amanda Woodward - sq 135/bp67.5/dl/135 - total 337.5kg
90kg+ open Rebecca Zepackik - 157.5kg squat
90kg+ sub masters - Rebecca Zepackik - 157.5kg squat
MEN
75kg open Emad Nayef - total 602.5kg
75kg sub masters - total 602.5kg
82.5kg teen 2 - Conor Zyskowski squat 200kg
90kg junior - Max Markopoulos bench 155kg
90kg open - Scott wasson 265sq/157.5bp/302dl - 724.5kg total
110kg open - Ricky Goodyear 325sq/202.5bp/320dl - 847.5kg total
110kg sub masters - Ricky Goodyear 325sq/202.5bp/320dl - 847.5kg total
140kg masters 2 - Spiros Markopoulos 235sq/150bp/140dl - 525 total
140kg+ open Zach Turner sq 310/bp 190
140kg+ teen 2 - Zach Turner sq 310/bp 190
140kg+ open - Jack Pollard - deadlift 280kg / 745kg total
140kg+ junior - Jack Pollard sq280/bp185/dl280 - 745kg total
Equipped bnench only - 140kg+ Zach Turner 250kg - open and Teen 3
Read more: http://prorawpowerlifting.proboards.com/index.cgi?board=results&action=display&thread=1401&page=6#ixzz27M3Kw8s3WOMEN
MEN
I believe it's something that creates a lot of elastic like tension across your chest...in ways similar to a sling shot? Will let someone who actually knows confirm.
Its a shirt :). Like this one: http://www.inzernet....T_ID=08_TPL_DEN although it depends on single ply, multiply et cetera.
It completely changes the lift, I've tried one on once and could not get 120kg to go down at all, I needed more weight. The tightness is more across the back then the chest when I tested out a bench shirt, but I've never competed in one or learned to use a bench shirt correctly.
There are also squat suits...these also change the squat and allow more weight to be squatted.
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
