i dont think hgh by itself would be that good, definently need it with other geasr to make it do what you want...
In regards to cycling and lifting, i know a fair few tour de france riders have giant quads which would partly be due to all the bike riding they do.
back on topic..
The worlds comp in Slovakia finished up.
The number at the end of each line is their glossbrenner score (look it up - it's a formula used to take in to account age and weight etc etc.)
Results and points of Oz team at Worlds
WOMEN
Nina 330kg @ 57.3kg - 669.83
Sussy 292.5kg @ 54.9kg - 575.99
Cami 325kg @ 69.3kg - 544.00
Tish 252.5kg @ 52.1kg - 526.88
Amanda 337.5kg @ 76.7kg - 515.03
Vicki 272.5kg @ 57.8kg - 503.69
Bec 377.5kg @ 112.3kg - 497.55kg
MEN
Ricky 847.5kg @ 107.8kg - 754.28
Scott 724.5kg @ 89.9kg - 702.04
Emad 602.5kg @ 74.2kg - 679.62
Max 650kg @ 86.4kg - 665.48
Jack 745kg @ 152.3kg - 629.96
Conor 500kg @ 81.1kg - 562.14
Dan 525kg @81.7kg - 543.90
Zach 565kg @ 144.8 - 500.08 INJURED
Spiros 525kg @ 126.6kg - 492.54 INJURED
57 new Australian records were set by those people above (records can be set for each lift or total so people can actually set up to 4 records in the one comp)
There were a whole bunch of world records set too.
Edited by TTT
Here are the Australian records...
WOMEN
56kg Junior - Tish Wasson sq95/bp45/dl112.5 - total 252.5kg
56kg Open - Sussy Kollen squat 112.5kg. Total 292.5kg
56kg masters 1 - Sussy Kollen sq112.5/bp60/dl120 - total 292.5kg
60kg open - Nina Markopoulos - deadlift 142.5kg, total 330kg
60kg masters 2 - Nina Markopoulos - squat 120kg, deadlift 142.5kg, total 330kg
60kg masters 1 - Vicki Jewson - deadlift 132.5kg
82.5kg open - Amanda Woodward - sq 135/bp67.5/dl/135 - total 337.5kg
82.5kg sub masters - Amanda Woodward - sq 135/bp67.5/dl/135 - total 337.5kg
90kg+ open Rebecca Zepackik - 157.5kg squat
90kg+ sub masters - Rebecca Zepackik - 157.5kg squat
MEN
75kg open Emad Nayef - total 602.5kg
75kg sub masters - total 602.5kg
82.5kg teen 2 - Conor Zyskowski squat 200kg
90kg junior - Max Markopoulos bench 155kg
90kg open - Scott wasson 265sq/157.5bp/302dl - 724.5kg total
110kg open - Ricky Goodyear 325sq/202.5bp/320dl - 847.5kg total
110kg sub masters - Ricky Goodyear 325sq/202.5bp/320dl - 847.5kg total
140kg masters 2 - Spiros Markopoulos 235sq/150bp/140dl - 525 total
140kg+ open Zach Turner sq 310/bp 190
140kg+ teen 2 - Zach Turner sq 310/bp 190
140kg+ open - Jack Pollard - deadlift 280kg / 745kg total
140kg+ junior - Jack Pollard sq280/bp185/dl280 - 745kg total
Equipped bnench only - 140kg+ Zach Turner 250kg - open and Teen 3
Read more: http://prorawpowerlifting.proboards.com/index.cgi?board=results&action=display&thread=1401&page=6#ixzz27M3Kw8s3WOMEN
MEN
I believe it's something that creates a lot of elastic like tension across your chest...in ways similar to a sling shot? Will let someone who actually knows confirm.
Its a shirt :). Like this one: http://www.inzernet....T_ID=08_TPL_DEN although it depends on single ply, multiply et cetera.
It completely changes the lift, I've tried one on once and could not get 120kg to go down at all, I needed more weight. The tightness is more across the back then the chest when I tested out a bench shirt, but I've never competed in one or learned to use a bench shirt correctly.
There are also squat suits...these also change the squat and allow more weight to be squatted.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
