Birds, the GPC National Push/Pull is on November 18, all around Australia on the same day
You can do both or simply one, so you can bench only, a lot do as its not a combined total, each event is separate
You can also set National records at this event. Being sanctioned, you must join GPC and wear a soft suit
The Vic leg is being held at my gym, PTC Frankston, 2 Skye Rd
Nick, leave a little earlier so you can warm up properly this time
you sound like my old man but you make an excellent point... I will leave earlier
my bro-in-law coming to watch again, been trying to convince him to enter but he's worried about his crappy bench press... I told him it's just the lie down between the real lifts and he had a good laugh... still wussed out though
I don't care if I come last (well maybe a little bit) as long as I beat my lifts from last time I'll be happy
Birds you should enter, last time I did I had done zero actual training for it... I had been doing all three lifts but with nowhere near the frequency or intensity of a proper program... I found it useful to gauge where I stood strength wise
My only reluctance is I'm still recovering from the drop in conditioning that the flu gave me. Right pain in the ass that's been.
Nonetheless, if I have nothing already planned for then and get hold of a soft suit, I'll come along to the Nov 18th comp. Be interesting to see where someone who doesn't have strength goals sits along the scale.
I've been running starting strength for 7 months and I've put on a lot of back size/width, but I do add chins and hanging leg raises once a week maybe twice, you do barbell rows as well (well I do instead of cleans)
Edited by Dani Boi
Birds, you may get a shock and your misconception of powerlifters will diminish
My son Max only deadlifts, rows, shrugs and chins, youll die when you see his back, same goes for Emad, Martin, Jesse, Wayne etc
Most think powerlifters are fat. Maybe the 125kg and up guys are fatter, but the guys under that are quite lean
if your interest is bodybuilding or physique competitions then I wouldn't go balls out to work your 1rms... however running a power lifting program for a few months definitely won't hurt your physique and it could spark some new growth, especially if your old program is a bit stale... its not something to attempt on a calorie deficit though so you need to eat... probably better to tackle during a 'bulking' phase for the physique competitor
Insert pics of Scott, Max, Mike, and Rankin here
I know, it would shock a few hey lol
Triple bodyweight raw squats and deads do tend to take a little bit of muscle to move
One of the comments Max always gets are regarding the size of his traps. They ask him what he does, and he says shrugs. When they repy they also shrug but their traps arent that big, he tells them he uses 220kg lol
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
