all i do is bench, deadlift, and pullups....sometimes squat when i'm not being lazy. Seriously i struggle to spend more than 40 minutes in the gym these days.
But i have abs....how does that work???
Cmon guys, by now you should all know abs/being lean/ripped whatever you want to call it, is all diet. You can squat 300kg's and be fat, and you can squat 300kg's and be ripped.
The weights don't give a shit about your physique, they just want to be lifted. You alone are in control of your physique.
On a side note though, the more muscle you have, the more you can afford to eat junk food and shit....like me eating ice-cream every night ;)
Results from todays Novice comp
Powerlifting
Vu - 78kg - 115/82.5/130 - 327.5kg - 219.21 points
Matt - 114.6kg - 125/95/200 - 420kg - 233.79 points
Brent - 99.7kg - 140/105/250 - 495kg - 288.11 points
Chris - 82.4kg - 160/120/180 - 460kg - 296.74 points
Nick - 86.4kg - 170/115/215 - 500kg - 313.17 points
Jesse - 71.3kg - 165/100/190 - 455kg - 325.62 points
Zoran - 112.8kg - 190/135/260 - 585kg - 326.86 points
Bench only
Dylan - 89.9kg - 92.5kg - 56.63 points
Spiros - 112.5kg - 145kg - 81.07 points
Martin - 86.3kg - 145kg - 90.89 points
Zoran beat Jesse by a point in the meet, awesome lifting by Zoran, this was his first ever meet. Zoran is the guy who contacted Bobby about PL in Frankston, and Bobby told him Frankston was cultural desert.
Zoran will be doing ProRawFour next month. Thanks Booby
Nick totalled 500kg, which was his goal, this is his 2nd novice comp
Brent pulled 250kg
Thanks to Emad, Graham, Wayne and Max for judging
Thanks to Jack, Ross, Pete, Daniel and Graham for spotting and loading
Thanks to Sussy for scoring
Thanks to all the lifters and large crowd spectating
Edited by markos
Thanks to all the judges and spotters/loaders... was great because everything moved so smoothly and quickly
cheers for the free Tshirt!... 'This object is the part of this territory' clearly someone in Slovakia was using google translate lol
looking at the video I think there was more in my bench and deadlift... pretty sure I maxed the squat though (it was pretty ugly)... Markos did say to take 165kg... so I took 170kg... maybe next time I should listen!
anyone who is thinking of having a go definitely should... pretty nice having people you don't know cheer you on... a very different atmosphere than your average gym
Good day out, atmosphere down there indeed really motivating (half the reason for my trip down), some very strong guys for a novice comp.
Solid effort Nick, 500kg total, huge!
Only took me 35mins to get home Nick, so realistically it's not that far provided traffic isn't farked. :D
wow that's great time... easy in that rolling couch your driving now;) good choice of car for after a squat session, a GTR isn't ideal haha
thanks for coming
TTT: cheers mate, hope you get that back sorted
Was good to finally meet Ash, I've know of him and known his mates for 6 years yet we've never met
Might repay the favour and support his new venture shotly
Lot longer than 6 years, I'd be pegging it at around 8-9!
Good to meet you in person finally as well, once I'm off shift work, I'll be down for a chat :)
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
