had a very successful States... I went 9 for 9, setting a PB on every lift
squat 210kg
bench 132.5kg
deadlift 240kg
unfortunately the 90kg division was very strong so I came 4th... if I had of lifted in any other division I would've got a medal
was an amazing job Markos, how you and the crew managed to run a meet with so many lifters and spectators out of that little gym was super impressive
bring on Nationals:)
Cheers! I had a good day... I like comps, I find I can get a few extra kilos just due to the atmosphere
I started doing PPP 3 times a week after my first novice comp which was last year in September I think... that was at my old gym with the odd weekend session at PTC... since mid Jan this year I've been training 4-5 times a week, mainly at PTC, doing a mixture of PPP and whatever Max tells me to do
booked in to have a coaching session with Trent from PTC Sydney next Saturday. Will be interested to see if I have been dead lifting or squating incorrectly.
also any other tips that he can give.
I think it will be more beneficial for my brother who has only just started going to the gym.
Nick, some are destined to stay weak and small, they'll never understand you eat for size and lift for strength, as you pointed out, Martin and Gregg are both Elite, different builds. Same training, one eats more. It doesnt seem difficult to understand. Anyway, please dont post that crap in here, its clearly a PL thread, PL is a sport.
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
