Body just a bit off on the breathing/hold timing and bingo it's lights out. On top of getting light headed , I used to get an occasional blood nose when I was doing heavy stuff back in the day but, apparently it's normal. Or at least I was told it's ok?
A mate of mine likes to do sumo; has recommended it often to me. He says it feels more autonomous to him; he doesn't have to think about his technique as much to do the lift correctly/safely. Still doesn't lift as much as me though :P
Well I gave Sumo a shot today to see if it pisses off my lower back like regular deadlifts always manage to...nope, absolutely no pain at all. It removes a lot of load from the lower back and send to hand it off to your legs lol. Managed to do better today than the last time I did regular deads.
Will definitely be doing Sumo deadlifts from now on, though I'll still get to sorting out WTF is wrong with my regular deadlift.
Its strange how many think sumos are easier than conventional.
The biggest deadlifts in history are all conventional
Benedikt Magnusson, Andy Bolton both over 1000lbs, Konstantinov, Koklyaev over 900lbs, even here in Oz Odell Manuel 400kg, George McLaren 375kg.
There is no doubt though that some are more suited to sumo. Here in the gym we have 2 guys pull 300kg conventional, Martin should be next and he has switched to sumo, Dan has 290kg conventional and Roger has pulled 300kg but not in a comp, he too is conventional
Wasn't Martins choice. His deadlift had stalled and Max decided to try sumo. Max also noticed that Martin had stopped front squatting.
Up until Nats, Martin trained himself, he went into Nats with the 2nd highest total at PTC, came out with the 7th highest, all those in front had been trained by Max, so he asked Max to train him.
His results will be skewed by the fact he has added bodyweight, so were not going to sit here and make outlandish claims BUT he went into Nats with a 685kg total and went 687.5kg in the same weight class.
First thing Max did was to get Martin front squatting again and to have a program for him. I think Martin will go close to 730kg at ProRawFive.
The reason Max switched his deadlift was to take advantage of his levers, Marty has long arms
He is currently the only PTC lifter doing Sumo
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
