  • 3 weeks later...
I'm going to a bench press seminar tomorrow hosted by Nathan Baxter at my new powerlifting gym. Very excited, but also not sure what to expect. I'm hoping to learn some tips and tricks; possibly readjust my technique as I have issues with keeping my knuckles pointing to the ceiling, and get back to my pb anyway! :)
just realised your post was old. how was the seminar?
Hey Nick, it was amazing. Nathan Baxter is a huge wealth of knowledge and quite funny!
He pointed out my bench grip is too close together and I'm using a lot of my triceps. At first, the wide grip felt horrible and I couldn't bench 40kg without help from my spotter. However; after a few goes I was easily benching 42kg for reps. He also gave me some great tips about crushing the bar on the way down, and focusing on keeping the pinky finger tight!
I got the most of the deadlift tips and tricks though. An important technique he taught us was breathing in and pushing out your stomach before lifting. I don't have much of a stomach to push out, so he suggested I use a belt. I'm also having my knees too far forward in my setup; hence all my knee bruises. He suggested when I set up to keep my legs straight as I bend down to touch the bar; only once I have touched the bar with my hands should I bend my knees. He had some great cues, which I think will be beneficial to me once I'm used to them. Deadlifted a pb of 102kg at the seminar anyway :)
I have now joined Dungeon Powerlifting in Bunbury, WA. I have my run through and programming session with the strength coach tomorrow. Hopefully you will be seeing bigger numbers out of me soon!
its amazing how much difference a proper set up from the top down can help your deadlift. I still need a fair bit of work on my technique which is why im going to join PTC canberra in january. Hopefully all 3 of my lifts benefit a bit.
PTC don't do speed/dynamic days
All good Mitch, just means your getting nice and tight and using leg drive. As you get stronger you'll be able to press the same amount and keep your ass down.
Also squat more = bigger ass... harder to get it off the bench! haha
  • Like 1
  • 4 weeks later...
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
