Hey ppl,
I own a r32 gtst with a rb20 and I want more power and a clean paint job do I was gonna widebody my gtst fresh paint and put a rb26 in it.
If I sell my gtst and instead of usin the money for that I can buy a r32gtr take ye front shafts out so it locks as hard as a gtst and put a 25 box on it.
Wuld this be defacing a gtr and can the rb26 take punishment from sliding ?
https://www.sau.com.au/forums/topic/408108-32-gtr-permanently-rwd/
Hey ppl,
Yes and yes
the 26 wont take the high revs to slide constantly, the 32s have shit oil pumps u will smash the bottom end and have to rebuild but after that will be strong.
LMAO! Perfect demonstration of a lack of knowledge about these engines.
1. RB26's have a higher rev limit. This number is calculated based on many different engine measurements and is still used today as a guide of an engines 'strength'
2. The oil pumps are identical
3. Maintain the car properly and you won't smash anything or need to rebuild.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
