Ev's - R32 Gtr - Targa/sprint/hill Climb Build
Nah Chris Tanner done my Cage, YT taught him though...
and i have a floor mount Tilton pedal box, so reaching the pedals isn't a drama.,.
Cheers
I just looked up the floor mount pedal box......another thing I hadnt considered. Very interesting indeed. Apart from adjustable floor position, what else do you like about them? Is it the bias adjust-ability? How much hassle is it to fit them? Looks like a dash out job to me, which is going to be hard now the cages extra a pillar supports are going in to my R32.
you are best to balence the car from the first build. I didn't put a pedalbox in mine cause i'm miserable, but i put the nav seat practicably in the back, which gave me a 56/44 weight distribution with driver and nav in (58/42 static). Most other gtst's are 60/40.
The GT-R have better weight distrobution cause of the heavier rear end, box/transfer case etc. But your still best to move as much as you can as far back as you can. If you don't do it now, you never will
Adjustablity was the key thing, as i tossed my ABS so i needed to be able to adjust front to rear, also more weight down low
the biggest plus is i can now see my starter motor, and unbolt it with ease!!!!, you understand this if you've ever had to pull
a GTR statermotor out.. :yes:
as for fitting it, yep Dash out, also had to cut a small part of the floor away to make it easier to move back and forth
if i was to do it again, i'd go with the canter lever pedal box, where the cylinders lay flat under the pedals..
Cheers
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
