Ok some quick questions
This is all i know about the N1:
"ALL N1 VEHICLES HAVE STRONGER BLOCK, STRONGER CONRODS, STRONGER PISTONS, LARGER STEEL WHEEL TURBOCHARGERS, NO AIR CONDITIONING, LARGE OIL COOLER, DIFFERENT WATER PUMP, DIFFERENT OIL PUMP, QUICK RATIO STEERING RACK, AND NUMEROUS OTHER SMALL CHANGES"
Also they didn't come with a radio or air con (???)
How much would they be worth over here and is there anything else different about them?
https://www.sau.com.au/forums/topic/40834-gtr-r33-v-spec-n1s/
The block, conrods and pistons are meant to be stronger but there is no evidence that indicates it is the case. The block number is different to that of any other rb26. The turbos are the same size but have steel wheels.
Larger oil cooler - this is not true since a normal gtr doesn't have a oil cooler at all however there is a huge nismo oil cooler. The suspension is also apparently slightly tweeked so the ride is a little firmer.
No radio thus no antenna, no air con, less sound deadening, no rear windscreen wiper, no vanity mirror, carbon fibre rear wing and front carbon fibre undertray etc.
They were only released in white.
IMO they should be around a $15-20k premium over a normal V-spec, that is if u can find one.
:( - good stinking luck finding one, you'd be better off trying to find an R34 GTR N1.
Its a pure track car, so only necesities, hence the no air con, radio etc...
Christian
Ive been looking for a V-spec at the japanese auctions for ages and managed to get a white N1 yesterday with 80000 on the clock, probably land it for around the 36G mark.  Ended up going fairly cheap, now just going to have to put the air con in!
Who is doing the compliance in WA for it and why would you buy an N1 and THEN put the aircon back in.
Think you might find that's a bigger job than you think as I would suggest the wiring isn't even in the harness.
Paul Rogers ( ex Wildcats ) had an N1 but sold it to a local guy over here. It was at Barbagallos and they were asking around 60K but that was a few years ago.
cheers
Ken
You wont need aircon in Canberra... at a guess id say the current temperature is well under 15 degrees :( and in summer it doesnt get overly hot, and if it does, just wind your window down :)
If you want the car to have aircon, why not just go for a R33 GTR V-spec? Its no N1, and you wont have a swish build plate, but you will have a car better suited for daily driving (which is the impression that rubs off on me if you need aircon)
But thats just my $0.02 ;)
Im interested in other peoples opinions so thanks guys, this car will rarely be my daily driver, more like a weekend car, basically i want it to have all the good things interior and exterior.
Yeah i could have bought a V-spec but this is a rarer car that has better go fast stuff (and also i got it cheaper than id been bidding on normal V-specs), ive got more money to play with if things go wrong or i dont like how something is set up.
Knore, not sure if it was overly raced or even at all as most of the other stuff on it was fairly standard - im sure i'll find out, if im too worried i'll just get an ASWN warranty.
Which brings me to my next question, if its been raced what stuff would normally be the first to go, given the internals have been somewhat strengthened?
Only reason i said that is because if something does break and requires an actuall N1 Vspec part then look out for the prices!!
Try and get it atleast dynod so you can see the power and air fuel ratios etc
I honestly wouldnt be buying this unless i was certain
hmm, just my opinion and its probably been said before.
but why pay the extra $20K or something to get an N1?
when u could get a V spec and with that $20K spend it on bettering a N1?
particularly if you are not going to race it?
like for a few $$$ you could upgrade to aftermarket turbos, fit an exhaust if it doesn't already have one, intercooler etc etc.. you could get those Volk TE37s that you wanted but cos you forked out all that more for the car and couldn't afford
and i am sure if you really want there is copies of the carbon under trays/ diffusers
or better yet you could put that $20K as a deposit down on a house
Well im getting it over here for only 36G!  Thats everything, stamp duty, tyres the lot, so theres a risk its been flogged but hey money fixes most things
I agree - for that money, it is worth getting! who here would knock back an actual N1 at that money?!?!?
Burto, if you end up getting it and come to Canberra, get the air con!! Nik, don't you remember how hot is was last summer!!! I would not have a car without fridgeability...
I imagine you can get the N1 complied the same as a standard R33 GTR.
sounds like a good price, congratulations, although, unlike what someone else said, i you will find that the N1 turbos are larger than the standard ones, they come on boost approx 500-800rpm later than the stock ones, making them similar to hks 2530's.
I know this for sure (im not just repeating something ive read on the forum) as i just rode in a friends car who recently fitted N1s.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
