  • Replies 61
Hey guys, I dont know if you would call this a thread bump. My currently upgraded 290rwkw [R34GTT] is too much power for my very stiff Cusco coilovers (not sure which model, doesn't have adjustable damping) in that there is not enough grip and it starts spinning and skating on boost and makes me look like an ass. I hate these coilovers, theres very little flex when pushing the car down from the back and front.
I am wanting to spend as little coin and soften up my rears, are a pair of BC BR rear coilovers the way to go? Or just get softer matched King springs or something? Front is ok, not looking to change that. cheers Ron
Edited by rondofj
Find out what spring rates are in your coilovers before doing anything else. You need to know where you are before deciding where to go. Read the thread on how to work out your spring rates, and/or remove the springs and test them yourself.
L I K E ! ! Thanks GTSBoy..
Remember Ron, i have more wasps and i can get mine to grip up sometimes.... You shouldnt have any drama's once you set it up right :)
Thats right, but these Cuscos are HARD, not good man, especially since theres no damper settings, well the clutch is in so one more thing off my mind...
Just installed these on my R34 GTT. Standard spring rates (8/6). VERY comfortable and streetable on soft damper settings. Also drove them on hard all round and was very stiff, good for track. Will probably get a bit softer once they wear in.
Edited by fusion07
^^^ +1 mine are in transit, BC the CHEAP way to go
FYP :)
They are a good cheapie solution but they are in no way magic, a quality set of coilovers will do so much more than the BC will..... I run them with no complaints, but if the car becomes more track oriented then they would be one of the first changes.... They are comfy though!
hahaha yea its a small fix i guess.....i used to have some Tein's on my 33 but that was way too stiff.....
These are basically like the oem, just a little firmer with adjustable height.
I still have stock one's on the 34 so this is a nice replacement :)
  • 2 months later...
All done! Set it on 6 soft setting. Seems pretty good till now for road use.
120mm at the back and 100mm at the front.
Did you set them soft 6 front n rear? I've just installed mine and it feels a bit bouncy... Any reasons to why ?
Cheers
I've read this a few times but every time I've read this noone has really linked or suggested anything that's obviously superior, and why..
As a newbie with little-to-no info re: suspension and relying on the SAU Search tool -> What would you suggest?
I have a 34, but its a GT chassis (with a non GT engine..), which I have read uses R33 style suspension.
Yet BC BR's have different part numbers for R33 GTST and R34 GT suspension.
I presume there are differences there so R33 is not exactly the same as a R34 GT.. so searching for R33 GTST gear may not even be compatible after all.
Theres a lot to be said for "it really is 100% compatible, cheap, and does the job", what else is out there thats the next tier up?
Pretty much BC BR and anything around that price mark (1100 - 1500) will be the same (and by same i mean same factory different paint). The next step up is, as GTSBoy said, more money - but it doesn't have to be thousands per corner, you could choose the tiny step of: 1600-2500$ for Cusco, Tein, Greddy, JIC, and if you find a good deal/stretch your budget, 3k$ will get you Ohlins. Though some people would argue that Cusco Tein etc are not worth the price...and I have to say I'm only speaking out of research I've done while deciding what to do, and speaking with people who have these coilovers.
You could also consider not using coilovers and going with a spring and damper setup instead. I myself have gone down this path with Bilsteins + King springs, I'm about to get them installed this week - I will rarely, if ever, use my car on the track/drift so coilovers and constant adjustability is not an issue. Set them up once and set them up correctly, leave it.
Oh and - I've talked to a few mechanics and they ALL recommend highly HSD.
  • 4 weeks later...
IMO: 8/6 is track, 6/4 is street. I live with 8/6 but on bad roads its a bit shit.
WRT the amount of adjustments whether 30 or 33 makes no difference. Some of these cheapo coilovers the adjusters do bugger all anyways according to the shock dyno, in that many of the adjustment positions are the same level of dampening. Ie, its ricey.
+1 to BC's with rubber mount top.
I just talked to BC technical support.
They recommended 6/5 for 'fast street' and 8/6 for track use.
They also said only the rubber tops (RA) make sense on double wishbone.
http://www.bc-racing.co.uk/applications/nissan-coilovers/nissan-skyline-r33-gts-93-98.html
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
