  • Replies 42
lol yeah I've heard WA and Queensland are a bit loose :P
sweet I'll check that out, but I recon it maybe cheaper to find an original air box, than somehow enclosing the pod(which is kind of next to the intercooler behind the bumper).
just a question, how much did the blueslip cost you????
i got quoted 130 bucks for a blue slip as it is an import...... i just got my girlfriends audi quattro done and that only cost 57 bucks.. why is the import more expensive?
btw everyone, had a proper look under the bonnet and took of some stuff off so I could see around the area better.
I found the bov DOES recirculate back into the uncompressed side of the turbo just after the air flow meter which is standard.....
the psssshhhh noise was coming out of the pod filter :P haha
So now I know that they can not ping me on the BOV anymore as it spec to standard recirculating not atmospheric, just have to add in the standard intake box to stop the noise :(
Also I found a standard R32 RB20DET air intake box for $10 on trademe.co.nz and with the exchange rate make that approx $8 yeaha! :D
Edited by niknac
thats an import complience plate, not a mod plate.
It tells you when & who compilied the car to meet australian standards when it was imported.
Edited by wedge_r34gtr
  • 3 weeks later...
right so, I have the standard air intake box (bearly fits) and the standard recirculating Valve fitted. Car booked in tomorrow at mechanics for blue slip. fingers crossed.
thought it was funny, I mentioned to the mechanic of the things I had fitted as he had asked and then he was like yeah sweet as and then when ya get home you can change them back....... lol
lol you are not going to believe this...
So I rock up to the Mechanics on Clark Road in Neutral Bay and the first thing he says is "have you fixed the oil leak". I'm like ummmm what oil leak??? he pops the bonnet and wipes his hand on the backside of the engine and is hand has some dirty/grease stuff on it, no way oily at all. I said to him dude thats not an oil leak thats a dirty engine the car is parked in the same spot and there are NO oil drips on the concrete so your full of shit.
He then processed to tell me he was not going to do it as he would be accountable for everything on the car if I got pulled over by the cops. I said well IF in that case I did get pulled over and the cops for some strange reason even wanted to ever talk to you, you could just say it was all standard to begin with(but why would they want to speak to you anyway! maybe if the car was in an accident).
I was pleading with the guy (I don't know why, guess I just wanted it done) to do the blue slip but still refused. So drove up the road to another place in North Sydney called Quixspede and booked it in there. I noticed they had some performance cars in their garage so maybe these dudes will know what they are doing..
hopefully.
stock bov is better anyway....
Stock ECU expects recirculation and as such runs better with recirc bov.
also stock bov is EASLIY good enough for most cars... i've been running 300+rwkw for years on mine (most it has seen is about 28psi)
also atmo bovs sound like aids
might as well keep it, save the cop hastle and have a car that runs better
oh really? the aftermarket BOV was recirculating back into the uncompressed side of the intake anyway, but yeah guess that could be a goer then if it can handle.
sooo the story continues:
The guys at Quixspede did the blue slip and said all I had to do was get a battery clamp (has cable ties holding it atm), get covers/lenses for the side indicators(the ones behind the wheel arch, as the light blub is exposed) and raise the back of the car 20mm as the lowest point on the car is at 80mm. I feel this is greatQ pretty easy to fix to get the car back on the road.
Today I fitted after-market side indicators, still waiting on delivery on the battery clamp and adjusted the adjusties. But ran into an issue, I did the back right side fine(wheel nuts were hard to get off) I couldn't for the life of me get 1 of the wheel nuts on the left side off :( going to a mechanic tomorrow morning to see if their air compressor gun can get it off. I actually bent my wheel brace trying to get it off. Adjusting them were easy, I was going to buy a c spanner but found a screw driver and hammer the better/cheaper option :P
Edited by niknac
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
