http://www.weatherzone.com.au/nsw/sydney/quakers-hill/forecast
30% chance of slight rain & high UV index, looking to be a good day so far...
bring sunscreen sunnies & a hat, or just be fabulously dark skinned like i am :P
  • Replies 147
It's always mega hot at texi days. Sux having to wear long pants and shirts when it's freaking boiling!!!!!
Better too hot than too cold. Bring on sunshine baby and stay away rain!!!!!
Any SAU NSW Financial Members will get championship points for entering this Texi. See the Annual Points Championship in the SAU NSW Members area.
For those of you that aren't dues paying members what are you waiting for? Discounts on events, member discounts with vendors, annual points championship and of course the SAU Members forum where we sit around talking about nothing.
I am still keen
Had all forms etc printed off at work but just never sent them through
Can all costs for the day (entry, cams licence and whatever else) be paid in cash on the day?
If i can just rock up and do that then i am there.
I am still keen
should be able to.
bring all the forms, and cash, and be early, need plenty of time to sort it out.
Is a cams day licence available or do you still need an AASA/cams licence aswell?
Sorry, was last year since did all this and have all expired since.
I am led to believe you can renew your CAMS licence online, and if you get some form of print out to prove that you have renewed it you should be fine.
AASA I'm not sure of.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
