Full length carbon fibre cooling panel for r32 gtr?? Not the small ones that go behind grill to radiator support but the full length ones from headlight to headlight and everywhere in between
Super keen
Also any news on CF intercooler surround for r32 gtr?
  • Replies 291
Super keen
Only the grill to rad. no full length. Can't find anything for the intercooler surround man :(
R34 GTR Diffuser fins available at all?
Nah sorry man :(
Hi. Is it to late for some r33 eye lids. Are there any pic. Is there any garage defend style coolong panel for r33 gtr? . Thanz
Still can order mate. PM'ed.
hey nice, i got your pm, ill send my details over and get payment details.. just need to check, the cooling panel for r33 gtr,
is it held in place by clips?, i see them in the pic, is it ok to screw in?, cf wont split or anything?.. thanx a heap..
I can't confirm that its clips or bolt over and I don't have a 33 to see. From what I gather from the supplier, it would be a bolt on application so it shouldn't split or crack unless under excessive tension. Probably some washers would help and prevent it from being damaged.
If in the event that it does crack during installation, I will seek a replacement for you.
Also would anyone be interested in R34 GTR CF Wing blades?
I know there have been some fitment issues with dori34's group buy, but apparently my manufacturers blades are shorter and would be a direct bolt on without mods. I am awaiting their response to confirm length with and without end plates. If it is the same length, end plates will be provided (fabricated locally).
Yo Julian, is that the wing blade you got from my group buy?
If so, looks good fitted man, what did you do to get it to fit?
Yeah it is. The wing stands as well.
I sanded down the original plates, took a while but better I think it fits very well now.
Ricky, keep me posted on that other part after it closes.
Cheers
Plattsy - R33 GTST Front grill
XKLABA - R34 eye lids, 34 jun high stands
stompy - R33 mirror cover, R33 GTST front grill
ADUBZ - R32 nismo gts gtr bonnet lip, R32 nismo boot lip
enka - R34 GTR full CF wing
Four-Twelve - R34 GTR OEM rear bar add on
TM7GTR - R34 GTR wing, FRP body, CF blade
SS- - R34 GTR wing, FRP body, CF blade
seriesII - R33 eye lids
photaii - RB26DETT cam cover, r32 gtr cooling panel, r32 boot lip
Please PM me if you would like to add or change order
can you put me down for the rear bar add-on too, cheers
can you add total and deposit required
XKLABA - R34 eye lids, 34 jun high stands, rear bar diffuser addon 34 GTR
Please PM me if you would like to add or change order.
Order updated. PM'ed for total price.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
