Stripping down my track r33, a lot of these parts are brand new.
Was close to being finished before i have decided on a different direction.
I have put everything at good prices, so don't be surprised if I don't want anything to do with lowballers
Can post a lot of things but WILL BE AT BUYERS EXPENSE!
Located in sydney
HKS 256/264 cams retaining vct
with HKS adjustable exhaust cam gear $500 very good condition
R33 RB25DETHead
Supertech valve springs
Supertech titanium retainers
Supertech valve stem seals
Supertech seats
Head machining including multi-angle valve job, oil gallery enlargement and decking, mild exhaust porting
This is all brand new, never been used, just test fitted.
$1000
RB25 Block
Good condition
Tomei oil restrictors
ARP headstuds
$250
Tomei 1.5mm headgasket $250
Apexi pod filter $20
New Z32 arm with tome plug $250
garret 3076r .63 turbo $1200
Tial 44m waste gate with screamer pipe $250
HKS cast manifold - machined flat $650
3" dump/front pipe $200
WIth new gaskets and studs
Will do the lot for $2000
Trust/Greddy 3.5inch titanium exhaust to suit r33 gtr/gtst $1000 - very good nick, very straight exhaust minimal bends
Greddy Inlet Plenum with
Q45 90mm throttle body $750
cat delete pipe $50
JJR coilpacks $100
HKS SSQ BOV $25
FUEL
Tomei 740cc injectors $600
New Sard Fuel pressure reg $100
Walbro intank pump $50
New Bosch 044 external pump with 1.5 litre surge tank $300
COOLING
Nismo intercooler $200
Alloy radiator $50
New Greddy remote coolant reservoir $100
HKS Type S oil cooler with thermostat $500
RB25 Gearbox $1000 with new nismo gearbox mount
Blitz/ORC twin plate clutch $900
Nismo braided clutch line $100
Nismo pivot ball $50
AME Tracer TM02 18x9.5 +22
Hankook RS3's 265's 85%
Hankook Z221 265's 90%
$3500 for the lot with those tyres.....if you know anything about how good these tyres are you'd know this is a good deal.
May separate
INTERIOR/ELECTRONICS
Racetech whr4009 seat/alloy side mounts $1000
RPM 3" Harness $50
OMP steering wheel with
Removable boss kit $150
Nismo leather gear knob $40
RB25 Apexi Power FC with h/c $900
Blitz DSBC $250
Braille No Weight battery $250
EXTERIOR
Carbon Headlight intake $150
Carbon F1 side mirrors $150
Aeromotions R2 carbon fibre self adjusting wing $2000
Will get pics up later on
mate probably a couple years, haven't done too many km's.
I change the plugs every 3000km's at the most, and when i do i clean and spray them with contact cleaner.
They are in very good nick
i have a build thread here which has a few pictures of random parts etc
http://www.skylinesaustralia.com/forums/topic/349246-33-gtst-streettrack-car/page__fromsearch__1
The shell will be for sale soon with all aftermarket suspension/kaaz diff and brakes also
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
