Stripping down my track r33, a lot of these parts are brand new.
Was close to being finished before i have decided on a different direction.
I have put everything at good prices, so don't be surprised if I don't want anything to do with lowballers
Can post a lot of things but WILL BE AT BUYERS EXPENSE!
Located in sydney
HKS 256/264 cams retaining vct
with HKS adjustable exhaust cam gear $500 very good condition
R33 RB25DETHead
Supertech valve springs
Supertech titanium retainers
Supertech valve stem seals
Supertech seats
Head machining including multi-angle valve job, oil gallery enlargement and decking, mild exhaust porting
This is all brand new, never been used, just test fitted.
$1000
RB25 Block
Good condition
Tomei oil restrictors
ARP headstuds
$250
Tomei 1.5mm headgasket $250
Apexi pod filter $20
New Z32 arm with tome plug $250
garret 3076r .63 turbo $1200
Tial 44m waste gate with screamer pipe $250
HKS cast manifold - machined flat $650
3" dump/front pipe $200
WIth new gaskets and studs
Will do the lot for $2000
Trust/Greddy 3.5inch titanium exhaust to suit r33 gtr/gtst $1000 - very good nick, very straight exhaust minimal bends
Greddy Inlet Plenum with
Q45 90mm throttle body $750
cat delete pipe $50
JJR coilpacks $100
HKS SSQ BOV $25
FUEL
Tomei 740cc injectors $600
New Sard Fuel pressure reg $100
Walbro intank pump $50
New Bosch 044 external pump with 1.5 litre surge tank $300
COOLING
Nismo intercooler $200
Alloy radiator $50
New Greddy remote coolant reservoir $100
HKS Type S oil cooler with thermostat $500
RB25 Gearbox $1000 with new nismo gearbox mount
Blitz/ORC twin plate clutch $900
Nismo braided clutch line $100
Nismo pivot ball $50
AME Tracer TM02 18x9.5 +22
Hankook RS3's 265's 85%
Hankook Z221 265's 90%
$3500 for the lot with those tyres.....if you know anything about how good these tyres are you'd know this is a good deal.
May separate
INTERIOR/ELECTRONICS
Racetech whr4009 seat/alloy side mounts $1000
RPM 3" Harness $50
OMP steering wheel with
Removable boss kit $150
Nismo leather gear knob $40
RB25 Apexi Power FC with h/c $900
Blitz DSBC $250
Braille No Weight battery $250
EXTERIOR
Carbon Headlight intake $150
Carbon F1 side mirrors $150
Aeromotions R2 carbon fibre self adjusting wing $2000
Will get pics up later on
mate probably a couple years, haven't done too many km's.
I change the plugs every 3000km's at the most, and when i do i clean and spray them with contact cleaner.
They are in very good nick
i have a build thread here which has a few pictures of random parts etc
http://www.skylinesaustralia.com/forums/topic/349246-33-gtst-streettrack-car/page__fromsearch__1
The shell will be for sale soon with all aftermarket suspension/kaaz diff and brakes also
    • I think in the modern era we live in, if I were converting a hydro lifter head to solid, particularly when chasing revs, I'd be seeing what I could do to use shimless buckets. Those of us with Neos usually have this persistent niggling fear of a shim getting spat out and ruining everything. Shim-over is...yucky that way. At least the Tomei kit appears to be conventional, but it would still be nice if they'd decided to go shimless.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
