Hi!
My Stagea 260RS is currently mapped to 575hp (497awhp), the guy who tunes my car told me to not go higher than 1.4 bars of pressure with my GT2530 turbos when running a stock bottom.
If I don't recall wrong, I've seen people here with ~600hp on stock bottoms.
A friend drove his R32 GTR for 80 000 kilometers with 560hp and a rev limit set to 8500 on a stock bottom RB26 over a 5 year period, the oil pump gears finally broke due to usage of launch for 2 summers.
How much boost/hp is safe?
Thanks
Mattias@Sweden
https://www.sau.com.au/forums/topic/408940-maximum-power-on-stock-rb26-bottom/
Hi!
Thanks
Mattias@Sweden
Do you trust your tuner?
Is this on E85 or 98 octane?
Mines making around 465rwhp stock bottom end for around 10'000kms so far on 98
No issues, compression still at 160psi each pot, done 2 drag days with another coming soon, on around 21psi
But I trust my tuner 100% and I'm prepared to rebuild "when" the engine has enough
Their is no magical limit depends on alot of variables like tune/condition of engine/fuel/ max revs etc etc
  • Like 1
How long is a piece of string?
Depending on age, use, condition, servicing, fuel - and anything else you can think of - will depend on how long it will last.
Will it last forever? Highly unlikely. Have seen people with only 450rwhp end up having to rebuild after 2-3 years of circuit racing as the motors just started to breathe heavy. So not blown, and not tune related, just age and use.
If you can't/don't want to rebuild, then don't chase the power. It's as simple as that really.
  • Like 1
thats very true.
+1 how long is a piece of string. Have seen plenty of blown RB26s that were still in mostly factory trim (stock turbos, stock tune, etc).
I personally wouldnt put 600whp through one and expect it to last very long at all. My personal feeling for a limit on these things is 500whp, and I'd put a very forgiving 30,000 km life on it at most (street driving with some fun here and there). Some people will have seen more, most would have seen less. Thats just my opinion from reading countless posts and knowing people who have built such setups.
Think also the main things are to keep oil temps under control with an aftermarket oil cooler
Run good quality engine oil (ester base 100% synthetic)
Keep intake temps down (turbos not at their limit pushing hot inefficient air down its throat)
Keep the rev limit sane (eg under 8000rpm)
Then you might have half a chance of it lasting abit longer
    • So my rb is finally having more problems. 2 issues here but I'm here to just to mainly discuss the rattle noise. The other day when I turned on the car and when I take off or go in reverse, there is a temporary rattle noise but when I cruise, boost, idle it's completely fine no rattle whatsoever. I've also done all the servicing, all the health checks you can think of and it all passes with flying colours.  Also the rattle doesn't increase with rpm, it's only at a very certain rpm (slightly above 1,100rpm). My other car also has the same issue every once in a while. Changed the oil recently, no difference. Even took my oil to a lab and everything was quite good surprisingly. Timing belt changed a while ago to. Had the car on the hoist and can't see anything obvious. Tightened a couple of nuts on the exhaust manifold a couple of months ago. 2 different clips uploaded. One of them was supposed to another issue but I'll save that for another time. Thought I'd see if anyone had this same noise before, it's a bit hard to diagnose while it's intermittent. If I'm not mistaken, I think I had this a while back but can't remember exactly. I was thinking if it's doable I'll get someone to hold the throttle cable at 1,100rpm and hopefully it replicates the sound. rb25det rattle only.mp4 rb25det slow start + rattle.mp4
    • Haha wow, yes they do! Will sort tomorrow.
    • Yeah I’ll know when I take it for a test drive and I’ll double check the turbos as well when I have a look at it again.  Just thought maybe they might have done something in the head cause it looks like they’ve taken off the rocker covers 🤔 Thanks for your info!
    • As Duncan mentioned it's likely a remapped ECU, like the the one listed in the link I post earlier:  https://minkara.carview.co.jp/userid/444260/car/444612/2099320/parts.aspx He quoted 444PS with an unopened engine and twin GT2510s @ 1.1bar boost... sounds about right?
