hey what use think of this i think it will look sweet
what i wont to do to my r34 sedan is toxic orange paint all around bn kit black drift tecs with camber low and manuel conversion shaved door handels? what ya think price iam looking around 8k
plates on it are gona be sour34 kinda like the 1 in the pic but diff
Edited by nissmore
https://www.sau.com.au/forums/topic/409121-my-new-project-r34/
  • Replies 45
Popular Days
Posted Images
re lambo door would look nice but there ilegal as ay
More to the point, they are aids!
well engine mods iam getn done atm/soon front mount manuel cam pistons coil pack what i have done so far is coil overs dump pipe and fixed a few things only had it for around 2 months
Whats a manuel cam piston?
I think your best to read as much as you can in terms of basic modification guides before posting :)
Nissmore, I'll give you a tip... Less is more.
Thats not what she said! :laugh:
OT - R34 is an awesome car, tasteful mods will go a long way. If you really want to change the car colour go for it as its your car :)
lol iam 22 and i ment to say cam and a manual conversion and my buddy says i should get forged pistons and ported heads but hes a commy person
and for u losers given me shit i have dyslexia so what now?
Edited by nissmore
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
