One of these babies:
14245764592_f0cc469c88_b.jpgEdit-3164 by 89CAL, on Flickr
The washer bottle wont really fit in front of the fuse box, the 3" cooler pipe is decieving in that photo lol, the washer bottle used to be zip tied there and I couldnt really mount it there properly. I was going to mount it under the front and have the washer cap sitting at one of the cooler pipe holes, but it was a bit to hard to do. Does the job where it is, until it melts through from all that heat lol
Yeah, Ive been thinking about spraying the coolant bottle black and just leaving a strip so you can see the level, but havent been bothered yet. Because It's a daily its not easy to justify taking it off the road for little things like that. Think I do have another power steering Reserviour that I might be able to do something with. Ideally I'd like an aftermarket one if I could find one
looks nice and clean.
That intercooler looks like its not finished, or something doesnt quite look right about it, but it looks good custom fit in there
That is my oil cooler.
Here is a pic of the intercooler.
I bought the oil cooler from ARE coolers in Queensland for $350.00 and used a plastic air diverter panel that was broken and used it as a template for a a mate to bend up some aluminium to shape without bonnet lock holes (because racecar) then welded the cooler to the new air diverter plate and mounted the oil filter to the underside of the air diverter for easy oil filter access and cooling.
oil filter under the air divert
Front bar fitted
  • Like 3
No only stage 1 with - 9 Turbo. Blown the stock Turbo and screwed one of the cylinder.
Ah ok, so hence the engine build, haha!
How do you find the setup?
I have a Stage 1 with -7's and is nice for the street.
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
    • Do this, and we'll have a resource right here.
    • "Hybrid" is a meaningless term. I could not tell you what the vendor of that turbo means by "hybrid".
