  • Replies 44
Give me a PM if you are selling the stuffed gearbox, I need a new case for my spare, it has a hole in it...
Will do, i was offered 20k cash for my car yesterday.. i may go ahead with that. I can get a work car now and the V will only be a weekender, saves me having to buy a new box and shit. The guys loaded with money anyway.
If you get it all installed, I would be interested to know what you think of the JWT Clutch/Fly and how it compares to the factory Clutch/Fly. I am getting sick of the feel of the factory clutch and the narrow engagement window - I have been thinking about the clutch pedal mods, but haven't got around to doing anything yet.
The downside is I have heard if you replace the factory DMF with a standard single piece flywheel, you get a lot of chatter from the gearbox which can be annoying at low RPM..
Well apparently the car has an excedy twin place clutch in it now, i've never driven a manual v35 with the stock clutch so i can't be too sure if it's legit..
I saw a factory CD009 at UPS last week. It was put aside because 1/2 the box was covered in fluid - suspect cracked case in transit - LOL!
Oh shit.. don't tell me that haha
  • 3 weeks later...
Update:
I have been in touch with Z1 performance in states over the last few weeks ttrying to find a better deal for what i want.
Here it is so far:
CD009 Transmission
Chromoly Pivot Ball
Stainless Steel Clutch Line
Nismo Pilot Bushing
JWT Clutch & Flywheel (tossing up between Nismo or UR flywheel as they supposedly have less chatter under 2000rpm)
Redline 75w90 gl4 gearbox oil + same stuff with gl5 for diff oil.
Z1 performance originally quoted me $1,699 + $775 shipping for just the gearbox alone.
I approached Coz at ConceptZperformance a while back and received no response, got an email back this morning from Coz saying "shit that's expensive i'll do it for $2194 delivered" definitely happy with that.
Definitely pays off searching around for a good deal as i'm very happy with saving $300.
Costing me a total of $3068 total delivered in 3-5 days which is great.
Now i just need the money!
Yeah cool cool he said he does alot of high value shipments to Australia and no one has complained to him yet about any GST or taxes lol so that'd be good if he does that.
Couldn't have picked a shitter time of the year to spend $3000.. around xmas and my mrs is expecting a shit load of presents as they do..
If they specifiy a figure under $1000 on the customs delcaration, you will probably be fine.. but just be aware, Australian Customs has been cracking down on this sort of thing recently.. hopefully they won't estimate the actual cost of the items to be above $1,000 and therefore won't invesitgate.
just wrap up little bunches of coal... your near a mine. it should be easy for you to get.
From what I know, if the declaration to customs states that the item is under $1k, customs duty won't apply.
However, if you do get it shipping insurance and it doesn't arrive, they will only cover what's on the declaration. Is $750.
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
