  • Replies 3.5k
Motley Crüe - too young to fall in love
Taylor swift - we are never ever getting back together
Reckless love - "hot" and "romance"
(YouTube it it's good shit)
Are the last four songs i played
Used to be a huge fan of ministry of sound a few years back. I can say they have just gone to shit...
That siad, the new spring 2012 annual is half decent.
MOS is for when ur in yr 9 and think thats what they listen to in good nightclubs.
