  • Replies 46
I just don't have the time to write up the guide, plus it may be a little confusing as it isn't an m35.
Che?
What do I drive? :P
Apologies for not putting up the comparison data, not so good with Excel so will take some time.
Excellent mod though and one of the first that should be done on a VQ25/VQ35 IMO
Che?
What do I drive? :P
A tractor usually. :P
I forgive you Cam.
Is this the same principal: http://www.conceptzperformance.com/Cart/description.php?II=3434&Car_Type=G35&UID=20121009182338150.101.79.229
Of course I don't think it'd fit on a VQ25DET but sounds like the same concept.
Same concept, without the thermostat, and they didn't fixing the air bleed issue. That is the pathfinder coolant mod, I imagine that assembly will hold air in the thermostat too.
Mine also replaces the stock plastic bleed point with a billet alloy body and high pressure ball valve.
Is this the same principal: http://www.conceptzp...8150.101.79.229
I looked at for some time Ryan and asked if it was bolt on and what, if any mods needed to be made to install.
The response?
"It is bolt on. It bolts onto the rear of the engine but you will have to cut and weld the pipe to attach to your coolant pipe"
(referring to the male/female fitting into the pipe on the driver side of the engine)
American "bolt on" is not the same as Japanese "bolt on". :no:
What?
Don't think its weld on. The original piece for my car (dunno about NM35s) has a female end, and the goldy coloured anodised piece pushes in and secures into the alloy pipe.
The kit seems to have a lipped edge- so it wouldn't push in, but a bit of silicon tube and a couple of clamps would sort it out just fine.
I think the bigger issue is the cross over exhaust manifold pipe, and the extra stuff round the back there.
I like how their kit "lowers temps by 20 degrees", when I read that... The temps are still controlled by the stock thermostat ffs.
Ours is the same female fitting Alex, but the cast alloy pipe is a different shape for that reason, it would hit the crossover I think. ^^
OK, no steak knives please ... I am a vegetarian!
But I do have a relatively standard 2001 stagea and my Galaxy series 2 phone takes good pics so I am interested.
Also as a noob who took a long time to do the brake wire cut simply because I couldn't find pics I think its important to have good visual guides up here. Yeah Yeah I didn't take the pics either... next time I have the glove box out and on the back seat I will do a step by step on the 'brake wire snip' for new noobs. If you don't send me steak knives and do talk me through it, I'll do the same for this. :rolleyes:
You need a 2nd person to take the pics, otherwise the camera gets covered in oily fingerprints. :P
I have ordered the fittings, they should be around a week away. When they arrive I will have 3 kits ready to send out straight away. For anyone else interested I can make them up as I go.
Dibs!
  • 4 weeks later...
I'm going to try and fit this kit up on the weekend. Would I be right in saying it'll take an hour or two to remove the plenum and get down to the middle of the V to fit the top plate, about half an hour to actually fit the kit, and an hour or so to put it back together?
Should be about right. You shouldn't have to disconnect the fuel rail from the lines, just flip it over onto the drivers side guard.
Make sure you silicone the top plate, you don't want it leaking...
Shouldn't need to silicone it.
We used a new gasket for each of ours although the existing gasket would probably be good enough.
Gasket is the same as on a VQ35 in case you want to grab one from Nissan, Ryan.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
