guys, this will be the 3rd one of these events i have held. if you value your pride and joy you need to attend this,
WHERE:
Audio Express
1 Silvyn rd
Redcliffe
(cnr anzac ave diagonally across from Mcdonalds.)
WHEN
October 11 from 6 pm - 8pm.
WHATS COVERED.
car security, common misconceptions, urban myths, install integrity.
there wil be some examples of this on a screen on what a proper install should look like and of course the horrible ones. i will pick off a car just to show how easy it is to take on of these.
V35 sedan owners are welcome to attend.
if you are silly enough to leave your car unlocked and in my sight it may get used as an example as well.
if you have an interest in this post below. if i know you personally ten a yes or no is enough.
IF I DO NOT KNOW YOU:
I want yor name, car rego and phone number pm'd to me. that way i have a register of who was there.
see you there.
I'm in (if allowed). Sending a pm now :)
of course you are allowed :)
its not a mates only thing. The last line is for my reference and if something goes missing in my shop OR off someones car.
Oh, I actually wrote that because I thought I read somewhere that only approximately 20 cars could come, or somethIng along those lines. :) all good, cya there!
Edit: found what I was talking about in the old thread.
"i do not have a set limit on these but i do have fixed space so 15-20 people is all i can hold. "
Edited by Bergo
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
