  • Replies 73
PM replied.
UPDATE:
Upgraded Turbos - SOLD
O2 Sensors - SOLD
Coolant intake temp sensor - SOLD
Thermostat Snout and Thermostat - SOLD
Open to offers on all items.
Cheers,
Pete
  • 4 weeks later...
UPDATE and PRICE DROP
- Drift Racing/Bucket seat, black, R34 GT-R style, comes with rails to fit all C34 Stagea (as was fitted to my Stagea), R32, R33, R34 Skylines and probably Silvias too. Will not freight, pickup only. Saw these in latest Autobarn ad (no rails) for $150...
$350 $200
- Tein "Type Wagon" adjustable coilovers to suit automatic C34 Stagea (Series I and II), "Low Down Spec Cool Style Master". Fronts have been rebuilt (with genuine Tein seals) and rods re-chromed. Have receipts, not fitted since rebuild (due to sale of car). Rears are still good. Adjustable spring seats, so adjustable in height, damping is fixed valve. Get on these quick!
$750 $650
- Stock Stagea rear upper camber/control arms, left and right side. Also have FR &RR swaybars.
$20 for both offers
- Space Saver spare wheel, T125/90D16.
$15 $10
- High Mount Twin Turbo Kit, gave me 347AWKW. Boxed up ready to freight!
$1600 $1400 ono
- R32/R33 S1 Coilpacks, full set, with mounting frame, 8000km old, P/N: 22433 60U02.
$150 $100
- R32/R33 S1 Coilpacks, full set, P/N: 22433 60U01.
$100 $80
- CAS with mounting bracket.
$100 $80
- R33 N1 dumps, with heat shields, 8000km old.
$100 $80 for both or $60 $50 each
- FR and RR hotside compressor outlet snouts, includes the rear OEM rubber hose.
$50 $40 for both
  • 3 weeks later...
32rrr,
As ^^^ above, the CAS is for R32 and R33 RB26.
Whitenight,
Sorry mate, all hoses (silicone and rubber) have all gone.
SOLD
SOLD
Deposit Taken, will be sold tomorrow.
Cheers,
Pete
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
