For a mild rwd engine they will be fine. They don't have a massive torque threshold like others but that's mainly due to the compact size.
As a guide the nz touring cars have around 450hp and 600-700nm from memory.
The boxes are very reliable behind those engines.
The Dubai guys do break them with the sequential shifters but watch some YouTube in car footage and you'll quickly see why they break them. It's no wonder Mal rose wiped the floor clean when he did a round over there.....
I haven't done the conversion from scratch but I've fixed a car that had a bodgy job done of the conversion.
We had to trial a couple of diff ratios to get a decent spread.
Works okay now the clutch and flywheel issues are sorted.
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
ok got it all in and up and running... was a bit of a headache but well worth it.
parts needed
3/4 bore master
quarter master hydraulic release bearing with custom made bearing extension to sit the bearing closer to the clutch
bellhousing
gearbox
custom tailshaft (i modified the front section of the stock s14 shaft, length is almost the same) yoke is Turbo 400 32 spline output shaft.. its huge!
custom gearbox crossmember
clutch (i used NPC rb clutch but with the spline changed to Chev 26 spline input shaft)
custom spigot bearing ( machined one up to suit the auto spigot area in the crank and protrudes out
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
