Just wanted to know what the fine for running a decat pipe is, and whether anyone's been done for it? I hear the fine is something ridiculous like $10,000 and mobile EPA officers at defect stations can d!ck you for this simply by getting an emissions reading and extrapolating the fact your car is passing out very dirty gases.....can someone shed some light on this?
https://www.sau.com.au/forums/topic/411852-fine-for-decat-pipe/
EPA victoria will apply to you: http://epanote2.epa..../$FILE/1031.pdf
Bare minimum fine looks like $1000 (1 penalty unit). If you knew how many penalty units having a decat would give, add 3 zero's on the end.
If I had to guess, you would get 1 penalty unit for every exhaust gas (nitrogen, water vapour, carbon dioxide, carbon monoxide, hydrocarbons, particulate matter, sulfur dioxide, nitrogen oxide, ozone?, lead?) which a cat converter would otherwise have dealt with on some scale.
So it's easy to see where the $10,000 fine can come from.
I would never run a decat Terry, I was just wondering because I was having this conversation with a mate and he told me the fine was in the vicinity of 10k which I found hard to believe :I
Holy @#$*, I don't know why people have them and run the risk of copping a 22k fine :/
I have never heard of anyone getting that sort of fine, Its not somethign that you can test really test for on the raod, Nor can your avg joe cop.
though if you rocked up to EPA with a decat you deserve the full ammount, Keep a stock cat on hand.
its not like your 100 cell cat will pass emmisions anyway.
^ this
all rumours, who do you know personally that has been fined? no one.
In NSW a penalty unit is $110, not $1000.
CRIMES (SENTENCING PROCEDURE) ACT 1999 - SECT 17
Penalty units
17 Penalty units
Unless the contrary intention appears, a reference in any Act or statutory rule to a number of penalty units (whether fractional or whole) is taken to be a reference to an amount of money equal to the amount obtained by multiplying $110 by that number of penalty units.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
