Its time to sell her, I am only selling her because im looking to buy a house or start my own business up.
Im in SA
She has done 68,xxxkm
Engine
Garrett 28/60-7 (only 10,000 km old)
Port matched turbo manifolds
ATI 1000hp Balancer
Sard Twin Entry Fuel Rail (500km old)
Sard 800cc Injectors (500km old)
Nismo Air Flow Meters (500km old)
Nismo Thermostat
Greddy intake piping
apexi pods
260 Tomei cams
Greddy adjustable Cam gears
Nismo engine mounts
Oil Catch Can
Full stainless steel 3.5" exhaust
Splitfire coilpacks
Huge Intercooler 100mm thick
Apexi Power FC and Hand Controller
New Xtreme Clutch ( only just put in )
Lightened Flywheel
Braking and Suspension
HKS Coilover Suspension all round
Standard Brembo brakes
Cusco Front and Rear sway Bars
Interior
Standard GTR bucket seats
Nismo 320km/h speedo
Nismo Floor Mats
Nismo Gear shifter
Alpine Head unit
DLS 6.5” front and rear
DLS AMP
DLS Sub
Cheetah Alarm
Exterior
Z-Tune Front Guards (Genuine Nismo)
Z-Tune Front Bumper (Genuine Nismo)
Z-Tune Side Skirts (Genuine Nismo)
Z-Tune Rear Pods (Genuine Nismo)
Z-Tune Rear Wheel Arch Flares (Genuine Nismo)
Z-Tune Style CF Bonnet
Nismo CF door pillar garnishes
Night Pager Wing Extensions
Carbon Fibre rear diffuser
Carbon Fibre Front diffuser
Rays/Nismo LMGT4 18x9
I have probably forgotten a few things but I think that's it.
It makes 275AWKW on 10.5psi. The only thing the car needs is a boost controller to easily make 330 -340 AWKW. Comes with books and receipts as well from previous owner.
The paint is perfect
The edge of the screen has a small hair line crack in it as seen in the photo.
It has had minor front damage (in Japan) but nothing serious, i have had the car checked over. Shaun From boostworx has serviced and checked over the car, any questions please give him a call
on (08) 8260 5566
Any other Questions please don't hesitate to call me 0403894492
Please no dreamers or tyre kickers, i will be the only one driving the car usless deposit has been put down
$52,500ono
Photos
Edited by Alex_23
  • Like 1
https://www.sau.com.au/forums/topic/412021-fs-1999-r34-gtr-v-spec/
  • 3 weeks later...
  • 5 weeks later...
Hi Alex,
Beautiful car. Just a few questions, does it come with / do you have the stock bonnet or was this part of the accident replacement?
Hi Alex,
Hi Chris
i dont have the stock bonnet and im not sure if it was in the accident replacement or it was bought and just swap out.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
